Author Topic: They’re back, the GMC Folding Bike Stand  (Read 25604 times)
« on: April 20, 2011, 10:12:40 am »
A long, long, long, long time ago,
1985 actually, after fancying myself as an entrepreneur and with much encouragement from friends I set about making the world’s greatest MX bike stand.
But instead I came up with these.
An old design which I found room to improve on.
By making the handle fold down they take up very little room in the boot of the car and they were easy to carry with the bike through the pits.
I sold a quite a few dozen back then, I could even be seen at the track taking in so much money that I would lay back, shut my eyes and dream about making frames and expansion chambers
Not long after the lift up stand hit the market.
I always found these to be cumbersome things to use as most of the time you still had to lift the bike over the stand or you had to push these awkward contraptions under the bike before you could hit the lift pedal.
These lift stands I’m sure would be great in the workshop but I always felt too awkward for the pits.
So with the lift stand being the new fad I dropped out of the lucrative stand business and pursued other interests (booze, fast cars, women etc.)
I’ve come a long way since those early days, (moved to Broadford, about 70 Km’s) and so several decades later, and still seeing some of my original stands around the traps, I have been asked by a few to start producing them again, commenting about old classics being photographed on big alloy stands that don’t look right for them.
Stands that are meant for moderns which leave the rear wheel of the old bikes 2 foot in the air, or just the unavailability of decent milk crates has left a vacancy in the market place and so I have decided to over capitalize on this and once again the GMC folding stands are now available.
Now in 2 different heights, to suit different models.
(Considering a 3rd model at 350 high to suit the first generation long travel bikes - feedback welcome)
300mm high - suits early up pipe models up to approx Pre 78 models
400mm high - suits late 70’s long travel bikes up to moderns.
Coming soon 300mm high to suit down pipe models.
I have one prototype for testing, this should be a one size fits all but I won’t know for sure until it’s tried on a few different models
Come and check it out at Broadford on Saturday and bring your bike to test it with.
$88.00 each  (complete with ugly thick powdercoat)
$22.00 flat rate postage anywhere in Aust.
Come and check them out at HBBB
GMC folding stands – “feels like having a party”
Re: They’re back, the GMC Folding Bike Stand
« Reply #1 on: April 20, 2011, 11:04:07 am »
I've just discovered that none of my stands fit my flat track Hindall because of the downpipe so if your sweet looking stand fits you can count me in for one Geoff. See ya on Friday.... ;D
« Reply #2 on: April 20, 2011, 11:53:37 am »
  THE poick up points for down pipe bikes will all be differant .  I have made 5 pipes over time and they only fit differant bikes as some you have to pic up the peg mounts other you can get some of the frame and so on  the issue is the pipe cover most of the rear pick up points and leave you with differnat width and angle on differant makers, ie my Suzuki TM is differant to the DT which is differant to the and so it goes on.   What i always though would be a good idea would be to use the u bolt type upper clamps so you dont get stuffed by a too wide a lift point being to wide to slide into the frame are ( see a TM)
This is the best stand i have, i got from the states a few years back and uses a arm with pinch bolts ( so it folds) but also the centre section slides into and out of itself so you can change the carrage width to use it on any bike.  Also the u bolt tops are threaded so you can wind them in or out to make the height you need or to balance out a angled floor etc orframe points.
As you can see it also clear Fat pipes under the frame.
So Thats the go and then you have one model that can truly fit all.  If if i can get to the back of the room ill take a picture and right down the make.  ITS under my YZ in this picture.
« Last Edit: April 20, 2011, 12:12:16 pm by Freakshow »
Doggy Digger
« Reply #3 on: April 20, 2011, 02:39:36 pm »
« Reply #4 on: April 20, 2011, 03:20:00 pm »
are they aerioles or just nipples on that shirt
« Reply #5 on: April 20, 2011, 07:27:10 pm »
I have avoided adjustable versions as it adds a lot of fiddly bits to the fabrication and I feel they may become a bit flimsy.
I have measured a few frame rails on different models and made the top of this stand to suit most rails, although the rubber stole a bit of room from this prototype.
I had also been wondering about those models that have the pipe hard up to the frame rails. But hopefully with a bit of testing on the weekend I will understand better what’s needed.
Orioles Freaky, they’re a US Baseball team
And why are you staring at my nipples
« Reply #6 on: April 20, 2011, 08:57:58 pm »
He's from SA
« Reply #7 on: April 20, 2011, 09:08:21 pm »
Mmmm feels good? What the money in one hand or what he is playing with in the other???
 Great stands Geoff will you be designing and that may fit my sidecar?? :) Cheers Buggers
« Reply #8 on: April 20, 2011, 10:51:06 pm »
I think you need to be searching out car hoists Tim, allthough could be a bit tricky at the track.
How often do your wheels fall off anyway;D
Will we be seeing you this weekend or will you be stuck working?
Offline piney
« Reply #9 on: May 17, 2011, 10:23:57 pm »
You bringin any samples to CD 8 ? Can I place An order  :)
« Reply #10 on: May 17, 2011, 10:52:20 pm »
Is that little Geoff there....I see you where riding a Yamaha back then...where did you go wrong?....We are hoping to see you up here for CD.....hows me pipes? :-*
IT400C
« Reply #11 on: May 18, 2011, 02:08:48 pm »
Ditto.  Are you coming to CD8?  Will you be selling them there?
« Last Edit: May 18, 2011, 02:19:05 pm by IT400C »
« Reply #12 on: May 19, 2011, 09:47:00 am »
Ah yes, the good old days when I was little, funny how I always saw myself as fat back then.
Newry, HK ute & YZ 250 N, one Yamaha that I only mildy hated, the rest that I owned I loathed.
Doesn't look like the planets will align for me in time (still haven't won Tattslotto) so I won't be venturing North for CD8.
Now available in 350mm high as well as 300 & 400 high
I have several sizes in stock now, can post anywhere.
Offline EML
« Reply #13 on: May 19, 2011, 03:29:20 pm »
Looks like you are opening a can of worms Geoffo. Every-one will want stands and no-one will get their pipes. You could set a junior at making the stands to fund the trip to CD8 :D :D :D
Do you have an air-operated one to go with the electric start on the new "wonder bikes"?
Offline TeeBone
« Reply #14 on: May 23, 2011, 05:04:44 am »
Here is one of GMC's stands in use and it's just like a Delmonti suit - looks good, feels good, IS good!
