Author Topic: Interchangeability of Honda CR 450 1981 and Honda CR 480 1983 ELECTRICS  (Read 2409 times)
Offline crabman
Anybody know if these bikes electrics are interchangeable ? Fly wheel, coil and CDI ?tHANKS
Old and slow - and happy
ianscr250
as far as i know yes but you will need to set the timing on the flywheel to suit your needs
090
Well I would be inclined to say no myself. They change so much from year to year. I tried to put a kickstart shaft between an 81 and 82. They look the same but are slightly different and won't fit. I have a feeling the 81 and 82 are closer but from memory the 83 system is different just to look at.
Offline caps 999
stroke is the same i know that much just the crank keyway that may be an issue but either way why not run an 83 ignition
MUGEN power
