Author Topic: Nickal plating.  (Read 1337 times)
Offline popeye
Nickal plating.
« on: April 19, 2011, 04:56:48 am »
Any body no where to inqiure about renickaling a sidecar frame any info would be great.
Re: Nickal plating.
« Reply #1 on: April 19, 2011, 10:52:45 am »
 Warning ,Is frought with heartbreak Popeye.  Old used frames are the big problem. Before pickling and replating, without a total and very comprehensive and extensive removal of old nickel and full repairs to any tiny tiny cracking or other even mildly dodgy bits, ... You could, no will , be very disappointed at the results. If the frame has been hanging on a wall since birth it should be OK. Oh have I mentioned the sickening crap done to old metal by "over pickling"   Suggestion use paint.......... ;)
« Last Edit: April 19, 2011, 11:03:54 am by Tim754 »
Re: Nickal plating.
« Reply #2 on: April 19, 2011, 11:49:26 am »
there is a close silver powder coat now available. whcih if not bright enough you can go over with chrome in a can.
not the same i know but cheaper, safer ( old frame acid bathed erode inside) and reversable.
