Author Topic: Con rod lenght  (Read 2189 times)
Offline Graham
  • Fast TT meets Drunks Hill
Con rod lenght
« on: April 04, 2011, 10:16:23 pm »
Is it possabile to fit a longer rod to a crank , eg. a 64.5 to a crank that has a 56.5 rod, without having to relocate to big end pin ???
Gosh its a shame a slow 4 stroke trail bike can go so Fast !!
Offline brent j
Re: Con rod lenght
« Reply #1 on: April 04, 2011, 10:28:27 pm »
Put a spacer under the barrel equal to the difference in rod length and modify the inlet and exhaust on a two stroke
Spacer and longer cam chain or push rods on a four stroke plus inlet & exhaust although sometimes the accessories will just "twist" a bit and line up.
I've done both in the past
Re: Con rod lenght
« Reply #2 on: April 05, 2011, 10:56:54 am »
Piston with a shorter pin to crown height.
Re: Con rod lenght
« Reply #3 on: April 06, 2011, 05:44:45 pm »
All of the above or some of, but depends on what you are trying to do?
what are you trying to do and on what would help the answer
