Author Topic: HL's are better than Maico's  (Read 6611 times)
« on: April 04, 2011, 09:30:54 pm »
Okay, now that I have your attention ;D
Can anyone tell me when maico changed from the conventional spring mounted exhaust springs to the single large spring over the single long bolt into the barrel?
I thought they started the single spring / bolt on the 79 models.
can anyone confirm please.
Geoff
Re: HL's are better than Maico's
« Reply #1 on: April 04, 2011, 09:48:43 pm »
Hi Geoff
The 250, 400, 440 all used the expansion spring type exhaust manifold part#467, on all years up to and including 1980
The 1981 model 400, 440, 490 were changed to bolt on compression spring manifold part#6893.
Except for the 250's which still uses a stretched expansion spring to hold the chamber on, but from 1981 onwards the arrangement was changed to a spigot manifold that is a part of the alloy cylinder casting.
« Last Edit: April 04, 2011, 10:08:54 pm by MICK-DE »
« Reply #2 on: April 04, 2011, 09:54:39 pm »
68 125 is an expansion spring, although it looks like a handyman conversion ???
69 125 roadie is a bolt and compression spring.
74 MC125 GP is bolt and compression spring.
75 Gs 125 is bolt and compression spring.
« Last Edit: April 04, 2011, 10:09:33 pm by MICK-DE »
« Reply #3 on: April 04, 2011, 10:11:31 pm »
Well I guess the 79 I jigged from had the wrong manifold on the barrel as it was the bolt & compression spring type.
I just had to change a 79 pipe today to the expansion spring type.
Thanks Mick
250 Magnum
« Reply #4 on: April 04, 2011, 10:24:31 pm »
US Maico Service Bulletin dated March 9 1979 states that a bolt and bush has been installed instead of a tension spring on the exhaust. It also gives the engine numbers from where this change will take effect.
Danny
« Reply #5 on: April 04, 2011, 10:41:02 pm »
It is a common mod to retro fit the bolt type. It simply is more reliable especially as for as leakage is concerned. The mere fact they made a change shows there was need for improvement. But all factory parts lists support what I have stated.
I would love to add a copy of that Service bulletin amendment to my Maico library, if you wouldn't mind throwing it up please Danny.
« Reply #6 on: April 04, 2011, 11:10:25 pm »
All of my part lists are factory and appear identical to these examples in active web addresses.
78 part list
79 part list
80 part list
81 part list
All of my engines share the same exhaust flanges as these factory lists.
250 Magnum
« Reply #7 on: April 05, 2011, 01:24:23 pm »
I have a copy of the service bulletin ready to send, PM me with your email address and I will send it to you.
I would post it here but it is far easier to split the atom than it is to put a photo on this site.
Danny
« Reply #8 on: April 05, 2011, 02:39:37 pm »
Thanks for your help guys.
I guess the question needs to be asked of the customer everytime I build a pipe for these models.
Check this out
http://ozvmx.com/community/index.php?topic=17785.0
TM BILL
« Reply #9 on: April 05, 2011, 03:13:36 pm »
Danny
Splitting the atoms easy  ;) just send it through the post marked FRAGILE PLEASE DONT BEND  ;D
Offline Canam370
« Reply #10 on: April 05, 2011, 03:24:56 pm »
Splitting the atoms easy  Wink just send it through the post marked FRAGILE PLEASE DONT BEND  Grin
 :D
« Reply #11 on: April 05, 2011, 05:23:08 pm »
Danny
 :D :D :D
Great stuff Danny, I will send that PM now, cheers.
« Reply #12 on: April 06, 2011, 04:36:53 pm »
Danny
Thanks Danny, I nearly went insane last night, it wouldn't upload to Photo-bucket ???
In the sober light of today, It finally dawned on me that the file was too large in megabyte size.
I finally figured how to reduce it, and Bingo ;D
They say if you learn something everyday, it should be  a good day.
Got me stuffed, but thanks for the education Danny and addition to my library.
[/quote]
Cheers, Mick.
« Reply #13 on: April 06, 2011, 04:59:49 pm »
This time I have printed it and the shot it with the camera a couple of times, that's the quickest and best I can do, no more. I WILL be needing a Valium or something now.
250 Magnum
« Reply #14 on: April 09, 2011, 12:02:52 am »
No Worries Mick, sorry about the big file size, next time I will try saving it as a PDF file and see if that makes it easier to handle.
Danny
