Author Topic: 84 cr 250 front fork info?  (Read 3767 times)
Offline Kane Mcguire
« on: April 01, 2011, 09:18:47 pm »
looking for what does the honda manual actually state for fork oil amount? not an opinion as i want the honda spec.  thanks
STW996
Re: 84 cr 250 front fork info?
« Reply #1 on: April 02, 2011, 03:41:36 pm »
84 CR 250
Per leg
562 CC
19 OZ
146MM from top
5.75 inch
That should cover it.
« Reply #2 on: April 02, 2011, 10:18:27 pm »
thanks, been looking everywhere for weeks.
Simo63
« Reply #3 on: April 03, 2011, 11:43:04 pm »
84 CR 250
Per leg
562 CC
19 OZ
146MM from top
5.75 inch
Hmm ... I've been told different when it comes to the level from the top .... a fair bit less than 147mm?? Sorry to question you but are you certain of that and have you ridden with that level of fork oil in each leg?
Craig
STW996
« Reply #4 on: April 04, 2011, 06:11:46 am »
Easy way to check, use the 562mm which is straight out of the Honda manual, the measurment came from the Clymer manual
« Reply #5 on: April 04, 2011, 07:22:24 am »
84 CR 250
Per leg
562 CC
19 OZ
146MM from top
5.75 inch
Craig
That would be the standard recommended setting but they were always too soft.. 120mm from the top would be a more suitable setting by todays standards.
STW996
« Reply #6 on: April 04, 2011, 11:02:44 am »
Yes John correct but K20 was after the actual spec and that is waht is in the book.
I run more oil myself but too each his own.
« Reply #7 on: April 04, 2011, 09:38:49 pm »
yeh i was after the honda spec as a starting point.
Simo63
« Reply #8 on: April 05, 2011, 07:54:30 pm »
Yep agree, each to his own.
By the way Kane, those forks on the XR should have been set to 130mm from the top.
Craig
Offline motomaniac
« Reply #9 on: April 05, 2011, 08:23:22 pm »
Racetech recommends 125 mm for the 250 and 120mm for the 500.
« Reply #10 on: April 05, 2011, 09:12:41 pm »
yeh got them at 146mm standard. trying it on a modern track tomorrow and will add more if it bottoms out. still looking for a cr rear end.
Simo63
« Reply #11 on: April 06, 2011, 08:22:30 am »
Have fun at the modern track Kane.  I rode the XR on the "modern track" at Kenilworth late last year and the suspension was struggling to keep up to be honest.  Bottoming out all over the place so I gave up riding it on that track and switched back to the CR instead.
I look forward to seeing you at Coles Creek on the big girl  ;D
Craig
