Author Topic: t/tree question  (Read 1185 times)
Offline frostype400
t/tree question
« on: April 01, 2011, 08:24:42 pm »
Different question I am putting a disc front end on my pe400 using a ts250x front end any way the ts triples have a different stem setup length I don't think they will work with out a fair bit of stuffing around so my only other option is some pe175z triples or I bore the originals the 36mm pe400 ones would it be safe to take them to 38mm or do I need to will 36mm trees work on the 38mm forks?
1971 tm400 and PE's
Re: t/tree question
« Reply #1 on: April 01, 2011, 08:53:08 pm »
Hi frosty, Check the dimensions?
Can you just take the stem out of the PE tripple and put it in the TSx tripples?
That is what I have done to a couple of my projects, admittedly my projects are not your exact order, but in my case, it was just what the doctor ordered.
Offline frostype400
Re: t/tree question
« Reply #2 on: April 01, 2011, 09:20:56 pm »
Yes probably could do that using the stock pe headlight if I got my hands on a ts250x speedo it would be a good combo I need a spedo I have bought excel rims etc etc going to make an oldie to ride and keep up/beat the new ones. ;)
1971 tm400 and PE's
