Author Topic: SPEEDWAY for Dummies: Part (a) ...  (Read 1254 times)
Doggy Digger
« on: March 31, 2011, 09:05:38 pm »
Hi Slide crew,
Could you explain please, what is the little helmet stick for - that I've seen in a few
1970s photos, that points out of - and a bit above the view of - the helmet peak?
  One I saw also seemed to have a little black knob at the end.  I guess you could call
it a Peak Stick.
   Is it a sighting thing, for following curve of the track?   The ones I've seen seem
 a bit too high to be use as a 'sight' ...
« Last Edit: March 31, 2011, 09:10:55 pm by Doggy Digger »
Curly3
Re: SPEEDWAY for Dummies: Part (a) ...
« Reply #1 on: March 31, 2011, 09:25:36 pm »
Doggy, anything attached to the peak was generally for tear off like devices.
There was a spring loaded mechanism that would hold 3 - 4 little pieces of perspex and all you had to do was hit the lever with your left hand and the dirty one would flick up out of the way.
There were many varied options around the time.
« Last Edit: March 31, 2011, 09:28:15 pm by SlideRulz »
Doggy Digger
« Reply #2 on: March 31, 2011, 10:41:07 pm »
Thanks SlideRulz.   I get it now!
