Author Topic: castrol r30 mx rate in rm 125  (Read 4023 times)
Offline asasin
« on: March 31, 2011, 04:51:06 pm »
can anyone tell me or is using R30 in a 125 . what ratio? i have been told 16:1 20:1and 25:1
John
If in doubt ,WIND IT OUT
Re: castrol r30 mx rate in rm 125
« Reply #1 on: March 31, 2011, 05:24:05 pm »
Running R 30 in  my 125 b   @  20:1
Offline asasin
« Reply #2 on: March 31, 2011, 05:32:10 pm »
thanks stu
« Reply #3 on: March 31, 2011, 05:34:21 pm »
25/30 : 1 guess it depends ojn what you have the carby Jetted to take really.
« Reply #4 on: March 31, 2011, 06:10:17 pm »
I ran R30 for a number of years at 50:1 in every two stroke I had. LOTS of carbon build up and stains EVERYTHING it touches orange. (lucky I run KTM'S ) Changed to Maxima 927 and haven't looked back, far less carbon, less smoke, upon pull down nice thick coating on everything. Nothing wrong with R30, but I think Maxima is a better castor oil.
« Reply #5 on: March 31, 2011, 06:29:03 pm »
which r 30 are you going to use syn or castor
i run evrything 20:1
Offline asasin
« Reply #6 on: March 31, 2011, 06:29:14 pm »
Thanks Guys . does it seperate when not n use and do you have to empty everything between meetings, this motor is fairly warm and the comp is pretty high , been using belray s7 but found it has no give when on the edge , when you get a seize even if you are quick and hear it comming the engine is F$$%^^ed and a rebore is required.
« Reply #7 on: March 31, 2011, 08:25:20 pm »
John , Evo is spot about the orange staining. I only mix what I'm going to use, and the left over is used in me hedge trimmer  ;D
Offline DR500
« Reply #8 on: April 01, 2011, 01:48:46 pm »
I use 20/1 in RM125D. I am the same, use left overs in garden power tools.Smells great when cutting grass!!
Offline bazza
« Reply #9 on: April 01, 2011, 02:39:11 pm »
changed years ago to Motul at 50.1 never has wear on piston since,runs cllean
Embrace patina
