Author Topic: Shocks for TY175.  (Read 5415 times)
Shocks for TY175.
« on: March 29, 2011, 10:28:45 pm »
Any recommendations?
No set budget - saving money is always good, but I'll pay a fair price to get good shocks.
Re: Shocks for TY175.
« Reply #1 on: March 30, 2011, 05:13:03 pm »
I'm running betors on my 250, cost under a 100 pounds+post from the uk.
Rest depend on depth of your pockets are magicals are closer to 400 from the sounds of it
« Reply #2 on: March 30, 2011, 06:05:46 pm »
montynut
« Reply #3 on: April 04, 2011, 11:30:12 pm »
Nathan I have fitted NJB to 4 trials bikes they range from 88GBP to 128GBP. The Rock shocks are excellent but much more expensive. Falcons are also excellent but again expensive. The Betors are inexpensive but I have seen numerouse shocks fail regularly to the extent that my local twin shock club has a member who always carried seals etc to help out other members. The Sammy Miller ones are based on Betors although I beleive are aluminium bodied and have upgraded seal heads.
I have basic NJBs on my TY175 with the single tension springs and there top 'trik-shocks' fitted to my Cota 242 and have been very impressed with both. The best set up for a TY175 is to use longer shocks (by 25-30mm) than standard which increases rear ride hieght and then you can slide the fork tubes further through the triples to equal the rear increase. This improves ground clearance which is a little lacking on the 175. With standard length shocks the fork tubes shoulds extend 40mm through the triples.
The NJBs are not rebuildable but the manuafacturer will sell a bare shock (not spring or spring lands etc) as a replacement as he claims the cost difference is marginal and often shocks are bent in trials which is the cause of failure anyway.
Oldbiker
« Reply #4 on: May 09, 2011, 12:15:44 pm »
I have Falcons on my TY250 and they are excellent! You can get them from Don newell in QLD
