Author Topic: Making an air box,  (Read 1770 times)
Making an air box,
« on: March 29, 2011, 08:51:57 pm »
Up date on Ts Hybrid ,   this is an extention added to guard to stop dirt entering air box
First I got some foam and contoured it  to get a feel of what it was going to look like.
Then I used 3 lb lead ....lead is easy to work with and can be very forgiving - put it in the sun for a few minutes to warm up and off you go. If you make a mistake and cut too much off clean the edges up with a (shave hook or knife ) and use a soldering iron .
Bottom pics show plugs on RHs and finished products to LHs
« Last Edit: March 29, 2011, 09:03:33 pm by oldfart »
Re: Making an air box,
« Reply #1 on: March 29, 2011, 09:00:12 pm »
Hows the engine going to breathe through foam that thick you silly oldfart ;D ;D ;D ;D ;D ;)
« Reply #2 on: March 29, 2011, 09:05:50 pm »
Joan, alot better I hope once it's completed ... should have a mock up tommorow
Offline PERM250
« Reply #3 on: March 29, 2011, 10:48:36 pm »
i like that stu very talented .
