Author Topic: jetting spec for 32mm mikuni 76 cr125  (Read 2383 times)
Offline ozyditcher
  • saddleback park made me leve Oz
« on: March 29, 2011, 03:48:12 pm »
 what are the jetting spec for 32mm mikuni on a  1976 cr125
Offline dkupf
  • Kinka Beach Qld
Re: jetting spec for 32mm mikuni 76 cr125
« Reply #1 on: April 02, 2011, 10:07:58 pm »
The jetting I run in my 32mm mikuni is. Main jet-240. Pilot-45 ,Needle jet holder-p8, Needle jet-159, Needle-6f21 (clip in the 2nd from the top groove), and a 3mm cut away slide. I also run a DG pro pipe which moved the power band up higher when I fitted it ::). Hope this all makes sense and helps you out.Darcy
Offline ozyditcher
« Reply #2 on: April 05, 2011, 01:20:05 pm »
« Reply #3 on: April 05, 2011, 02:44:38 pm »
Thanks for the link
"Americans have a knack for naming everything a “World Championship”...and in most cases they have the right to do it—because everything is bigger and better in the USA (and it would be silly for any other country or group of countries to pretend that they are holding a World Championship if the USA isn't involved"
It seems Americans have a knack for thinking they are at the centre of the Universe.
It's even more silly to have a world championship and not have any other country involved
Offline ozyditcher
« Reply #4 on: April 05, 2011, 03:39:59 pm »
Thanks for the link
I was there supporting Australia.
