Author Topic: KX 74-75-76 vs KE 75 -76 (125)  (Read 6972 times)
« on: March 28, 2011, 11:11:38 pm »
Can some one tell me if there is a differance between the KX125 and the KE125 cables ?
particularly around rear brake cable ( hub/pedal), front brake cable, throttle, clutch looks the same.
also is the KS125 - 73,74,75 seems to be the early KE is that similar too ?
# TMbill do you have any used KE 125 stuff over there you can try ?
TM BILL
Re: KX 74-75-76 vs KE 75 -76 (125)
« Reply #1 on: March 29, 2011, 05:53:07 am »
Im onto it freaky will report back  :)
« Reply #2 on: March 29, 2011, 11:50:41 pm »
bought a front brake, clutch and a throttel so far, for KX so hope they fit.  rear not sorted yet as i cant figure out if the KE is differant to KX - is it like the ealry TS fitting ?
TM BILL
« Reply #3 on: March 31, 2011, 11:51:30 am »
Clutch and Fr brake cables appear the same , rear brake cable is different and wont work , TS one will be a bit short but RM 125 S / A / B should work  :)
KE throttle cable is a short one that goes into a spliter to the carb and oil pump so wont work either  :(
« Reply #4 on: March 31, 2011, 02:02:07 pm »
Also looking for a used KE or simlar up and over exht pipe ?   or so i belives, you got anythign over there TMB ?
« Reply #5 on: March 31, 2011, 03:13:55 pm »
Actually i reckon an under KX will fit but dont quote me.   (its a KE BArrell ? )
Offline bazza
« Reply #6 on: March 31, 2011, 03:30:09 pm »
slider looks cool
Embrace patina
TM BILL
« Reply #7 on: April 01, 2011, 10:21:31 am »
Freaky yep i got a pipe you can have just pay postage . However i think you would be better off with a proper chamber as the KE pipe is a traily pipe and wont give great performance  ;)
Does Geoffrey make one ? Lozza made a great little pipe for Kens 125 (whitch incindentley would have to be the coolest KX125 A on the planet  8) 8) 8) ) so maybe hit the big guy up.
Im currently experimenting with externally mounted bigger carbs (ala Skunk works design ) on my KX 125 and an institute pipe could be the go on that baby  ;)
If you want the KE pipe let me know but the postage is probably better invested in a chamber  ;)
« Reply #8 on: April 01, 2011, 01:17:59 pm »
gIVE ME AN IDAE ON POSTAGE TO qLD,   ILL NEED TO SPEAK TO DAVE OR STEW TO FIND OUT IF IT NEED THE UP PIPE OR THE LOW PIPE, CAUSE I CANT TELL YOU WHERE THE BLOODY MOUNTS ARE ON IT.  THAT RIGHT FOOT PEG AREA JUST LOOKS LIKE A LOT OF BOLTS TO ME ?????
« Reply #9 on: April 01, 2011, 01:19:19 pm »
laST I WAS TOLD THAT tHE TOM GIBSON BIKE HAD A 250 CARB AND COVER ON IT ?
211kawasaki
« Reply #10 on: April 01, 2011, 03:27:53 pm »
your freaking out Kerry
just get the thing to the track, ride it and tweak it when you get home.
Pipe from KX will not fit, has to be a left port KE? which is the barrel your using.
Pin and rings are here, motor will be built this weekend
DT
« Reply #11 on: April 01, 2011, 05:18:33 pm »
Small end should be there too ?
« Reply #12 on: April 01, 2011, 05:28:26 pm »
Parden me for intruding but why would you want to put a KE trailbike pipe on your bike Freaky?
« Reply #13 on: April 01, 2011, 06:16:32 pm »
Was thinking the same myself.
« Reply #14 on: April 01, 2011, 09:32:00 pm »
as far as i know the only thing that will fit in the next 5 weeks ? Stewy is busy and i thought it was the only thing that was going to bolt up.  Happy if anyone wants to step up and modify a chamber so it can bolt up.
Can probally even find you an under slung TM125 pipe here i can send you, so can use it to MOd, if anyone up that way wants to give it a go  ????
Firko,  Dave and stewy are already doing a lot of pissing about on my behalf, and i dont want to burn out the freindship.   i cant get to the bike before the nats, so im just sending up anything i can to get it to run, anything else is a bonus.
I have never seen the bike so i havent got a clue, its like bomb disposal with a robot, and i have never even seen a kawasak,i so its all new to me and foreign
IF anyone wants to come on board for the 'progect freaky to the nats' we would love any extra help.....
« Last Edit: April 01, 2011, 09:37:49 pm by Freakshow »
