Author Topic: RM500 Rear Shock  (Read 5388 times)
Stankflapper
RM500 Rear Shock
« on: March 27, 2011, 07:44:11 pm »
Hi All, I am wanting to have a crack at stripping my rear shock, cleaning, painting and re-seal if required. Can anyone tell me if they have experience at re gassing nitrogen canisters, or where I can get this re gassed after I do the work?
Offline DR500
Re: RM500 Rear Shock
« Reply #1 on: March 27, 2011, 09:45:12 pm »
i stripped and changed oil in my RM125 D shock.I took it to a tyre shop that has a nitrogen cylinder to pressurise it.
Offline QLD779
« Reply #2 on: March 28, 2011, 10:35:18 am »
I have the luxury of being able to gas mine at work. Spec is 142 psi but I have run mine up to 280 psi to handle the extra load of a sidecar. This is about to be returned back to standard with a stock spring. Try a tyre shop like Bob Jane. They can charge up to that pressure. ;D
You don't have to be, but it helps.
Stankflapper
« Reply #3 on: March 28, 2011, 09:07:09 pm »
Thanks fellas, I called Bob Jane today, they can go up to 150psi. May have to fudge the rest as i dont have a gauge to go that high
Stankflapper
« Reply #4 on: March 29, 2011, 06:41:48 am »
I was just reading the instructions on the shock decal, and it states that max pressure is in fact 250KPa which is 36psi...........weird
Offline 270YAM
« Reply #5 on: March 29, 2011, 10:45:00 am »
Walter. . .?
Offline QLD779
« Reply #6 on: March 30, 2011, 03:37:08 am »
142psi is straight out of the manual. Like I said, I have run mine at 280psi which is what is in it now. I'm not sure what the pressure on the decal means as I don't have one on mine. 150psi will be safe. A hydraulics work shop can charge them as well.
Stankflapper
« Reply #7 on: March 30, 2011, 05:00:16 am »
Thanks mate, we have a great Hyd workshop down the road from us, I will try them.
Offline DR500
« Reply #8 on: March 30, 2011, 02:43:41 pm »
i put 150 psi in the RM125.
Not sure what would happen if you just pump it up with air?
Offline QLD779
« Reply #9 on: March 30, 2011, 04:47:27 pm »
The manual states a warning. Quote: do not exceed 20 kg/cm2 (284 psi) or the reservoir may rupture. After pressurizing the reservoir, the removal of the filler nozzle may cause some oil to be sprayed. Do not expose your face or body to the spray. Un quote. Hope this info is of some help.  ;D
Offline TeeBone
« Reply #10 on: March 30, 2011, 06:33:45 pm »
I know of a suspension tuner who does just that whilst testing. It's cheap and easy to do "in the field" and nitorgen really only comes into it's own after around the 20 minute mark...
« Reply #11 on: March 30, 2011, 07:00:02 pm »
10 bar or 145lb of nitrogen is what most shocks run. Any decent motorcycle shop will have a nitrogen bottle to regas shocks.
« Reply #12 on: March 30, 2011, 08:28:01 pm »
"Suspension Improvements"    ( Steve )  should be able to do it.
