Author Topic: yz 250 rotor  (Read 1253 times)
Offline asasin
yz 250 rotor
« on: March 21, 2011, 06:29:11 pm »
Dt 250 or YZ 250 up To "c" model. internal rotor (want to convert from points)
email:[email protected]
If in doubt ,WIND IT OUT
Re: yz 250 rotor
« Reply #1 on: March 21, 2011, 10:55:17 pm »
id go a little later stator if i was you. youll pay for a YZa/b set up and the DT2mx is points with an internal it think.  you be better off with a PVL or going later model YZ then you can use advancing CDi etc, also cheaper in the long run the real early stuff is 35 yrs old and so is the CDi and when they fail its a circle.
