Author Topic: Yamaha 100 twin or similar carb setup no longer wanted  (Read 1233 times)
DR
« on: March 16, 2011, 02:25:23 pm »
I'm on the hunt for a pair of carbs from a small 2 smoke twin for a project on the go. Even a pair of small carbs not from a twin would do so long as they are the same deal ;)  from 19mm to about 22mm should fit the bill..or fit the manifold in this instance ;D Cheers
« Last Edit: March 16, 2011, 08:50:33 pm by Doc »
Re: Yamaha 100 twin or similar carb setup
« Reply #1 on: March 16, 2011, 02:51:54 pm »
got little carbs off yam single think they are flange mount 20 somthings, will have a look over the weekend yours for the postage.
DR
« Reply #2 on: March 16, 2011, 05:07:25 pm »
oops, sorry Freaky..something I forgot to mention..they need to be spigot mount ala the picture below.. I have 1 from an old suzuki rotary valve steppy that will be perfect so I might try hunting up another of those :) nice little setup eh..this pictured from a Hoddy 100 from early 1968 8) dunno if it'll work or not but I'm going to give it a whirl for the heck of it :D
« Last Edit: March 16, 2011, 05:11:11 pm by Doc »
DR
Re: Yamaha 100 twin or similar carb setup no longer wanted
« Reply #3 on: March 16, 2011, 08:51:56 pm »
bzzzt..delete the request please..found a matching carb tonight whilst rummaging around ::) actually I found a whole motor I never knew I had :-[
monaro308
« Reply #4 on: March 16, 2011, 10:26:08 pm »
Well you better make room for another motor you never knew you had ;)
DR
« Reply #5 on: March 16, 2011, 10:37:51 pm »
 :D at least I should be able to remember where it came from Mario..mysteriously I just turned up another zook 70cc engine I don't really remember much about but it's a weird thang..rotary valve but the carb runs externally parallel to the cylinder i.e. it faces to the front of the bike not the rear :-\..stocktake coming up this winter ::)
« Reply #6 on: March 16, 2011, 11:33:38 pm »
I    used     to have one just like your description Doc.  :D  Cheers Tim754
