Author Topic: SEIZED BULTACO ENGINE STUDS  (Read 2788 times)
« on: March 15, 2011, 08:24:39 pm »
After soaking in Penetrene for a couple of days I managed to get 2 out (diagonally opposed for what it's worth) but the other 2 wont budge. Any ideas / advice most welcome. Cheers Jerry
Re: SEIZED BULTACO ENGINE STUDS
« Reply #1 on: March 15, 2011, 08:42:41 pm »
Yes worth rost off is the can of choice for the stuck nut person. Try some heat but if your unsure pay someone to do it. Good guys make it look easy and it's worth every cent.
« Reply #2 on: March 15, 2011, 09:14:35 pm »
What are you using to turn them with?
2 nuts locked together or a stud tool?
A bit of heat on the barrel will cause the barrel to expand more than the stud which should make it easier to come out.
« Reply #3 on: March 15, 2011, 09:50:04 pm »
stud removal tool is the go jerry as they bite in eccentric cam style the more pressure you apply the tighter they grip, but like gmc said get some heat onto it first, alloy expands faster than steel
« Reply #4 on: March 15, 2011, 10:41:07 pm »
Thanks guys will try a bit of heat. Let you know. Jerry
« Reply #5 on: March 17, 2011, 01:31:48 pm »
Studz are out! Thanks guys heat worked a trick. Cheers Jerry
