Author Topic: Swingarm bearing removal  (Read 2285 times)
Offline Bitten
  • Sydney, Australia
« on: March 15, 2011, 03:17:21 pm »
Hi All,
I have just started the resto on an RM465Z and after removing the swingarm the bearings crunch a bit like there is a fair bit of grit in them
The Clymer manual recommends their removal should be done by a Suzuki dealer. I don't have a press and if it can be done safely at home for both the bike and myself then any tips on removal and installing would be greatly appreciated
Bitten
Re: Swingarm bearing removal
« Reply #1 on: March 15, 2011, 04:13:18 pm »
http://ozvmx.com/community/index.php?topic=13804.15
Bit of info here,the end process posted by mainline of bearing suppliers ..good luck
cheers A
« Reply #2 on: March 15, 2011, 04:20:46 pm »
are they bearings or bushes > i pulled a few sets out or some yamaha 125 swingers this week and after a few days of failing i fould they came out if i used a T-bar socket from the other side and tapped, then swiched over when it came out and was able to go up to the full width socket on the other side.
I think it worked as the socket head was able to sit on at least half the area of the bush rim, were as the other tapping things i used where to small in ara and just shot off as i hit it.
worked for me...........
Offline Bitten
  • Sydney, Australia
« Reply #3 on: March 15, 2011, 06:11:17 pm »
Thanks guys
I have spoken to my local mechanic who does bits and pieces on my 'modern' bike and he is pretty good when it comes to invoicing so I think I will get him to do it properly, that way my kids wont learn more swear words!
As far as bearings go I have got some through Alpha sports and I spoke to the local CBC bearings fella and he said bring it in the components and he is pretty sure he can match them - Alpha Sports wanted $92 (ish) EACH for the the little swivel type bearings on the shock lever the push arms attach to.
Thanks for the response
