Author Topic: ball bearings  (Read 2539 times)
Offline maxi81
ball bearings
« on: March 04, 2011, 09:11:15 pm »
Does anyone know what size ball bearings are used for the steering head for a RM 400T? I took my old balls to a bearing shop and they sized them up and gave me new ones, but I think they are a bit smaller. I was told you need 18 ball bearings for my bike, but I needed 20. Does that mean the ball bearings I just bought are too small?
monaro308
Re: ball bearings
« Reply #1 on: March 04, 2011, 09:27:00 pm »
Not sure what size they are but they do take 18 balls.
Not sure why they leave a gap for 2 extra balls,but suzuki do.
I've been there and just fit the 18 as they specify.
cheers...mario
Offline maxi81
Re: ball bearings
« Reply #2 on: March 04, 2011, 09:30:47 pm »
Cheers Mario
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
Re: ball bearings
« Reply #3 on: March 04, 2011, 09:35:36 pm »
In the B/C/N models they used to fill the entire circle.
BUT they realised this tended to jam and I am fairly certain T had the gap - deliberately.
Lue
DR
Re: ball bearings
« Reply #4 on: March 05, 2011, 09:52:33 am »
The air gap is for the expansion of the balls due to the heat created from the super quick handling of the Suzuki's ;)
Seriously, the balls are a std 8mm for top and bottom for the N and T's. I've find usually on near any model there is not quite enough room to fit ball number 19 when the correct size is used ;)
« Last Edit: March 05, 2011, 09:54:09 am by Doc »
Re: ball bearings
« Reply #5 on: March 05, 2011, 12:39:12 pm »
Loose balls you can get from VXB bearings on ebay. Im just not sure if they have metrics though.
