Author Topic: PE400 Flywheel Puller  (Read 4344 times)
rohan
« on: March 02, 2011, 11:13:33 pm »
I need to grab a new flywheel puller for the PE. Can anyone point me toward the right one to grab (on ebay or other), ideally something generic that I can use on more than just one engine if possible.
Offline 500Fool
Re: PE400 Flywheel Puller
« Reply #2 on: March 03, 2011, 08:32:28 am »
I forget what a Suzuki one is like but a Honda/Yam one is a little colar that screws (Left hand thread) into the flywheel, you then screw a shaft (Right hand tread) into the centre till it grounds then just give that shaft a tap, springs orf no problems.
Offline AdamN
« Reply #3 on: March 03, 2011, 11:03:17 am »
That one should do the job. MCS do a Suzuki flywheel puller, get your local bike shop to look in their MCS catologue, or check it out online.
Adam
'82 PE175Z, '92 YZ125D1, '93 WR500ZE, '13 KTM350EXC-F, '16 Husky TE300
« Reply #5 on: March 03, 2011, 12:54:38 pm »
www.mcsonline.com.au The MCS ones are Dennis Stubblefield brand made in USA and im pretty sure the below websites carry the same ones.
also
www.repairmanual.com
www.denniskirk.com
http://www.mcas.com.au/pw/
Parts Unlimited do a Universl multi fit one. MSC has this aswell i think but i know www.denniskirk.com has it too.
« Last Edit: March 03, 2011, 12:57:46 pm by LWC82PE »
rohan
« Reply #6 on: March 03, 2011, 03:53:20 pm »
Offline lukeb1961
  • PE175N, RM80B, JR50C
    • PE175N
« Reply #7 on: March 05, 2011, 09:06:45 am »
you will find the RM one does not fit.
« Reply #8 on: March 05, 2011, 12:36:26 pm »
For mine i actually didnt buy the PE specific one and bought a Yam WR400 or TT600 puller. I cant remember which one it was but im leaning towards WR400. I dont know why i bought it either but i think it may of been that i could use it on the TS flywheels too instead of the PE specific one or maybe the PE one was out of stock or something i just cant remember. Anyway all i had to do was  drill the 3 6mm bolt holes out to about 7mm i think so the center distances lined up with the 3 threaded holes in the PE flywheel. Its a pretty compact tool. With a few lightening holes in the plate, you could take the tool with you one a trail ride.
Offline lukeb1961
    • PE175N
« Reply #9 on: March 05, 2011, 01:17:02 pm »
there are a few little tools that will make your life immensely easier.
See here for a selection of homemade whatsits:
http://cid-407d7ef0965d3991.office.live.com/browse.aspx/Pure%20Enduro/tools
