Author Topic: RM250 or 370 head?  (Read 3538 times)
Quicksilver
RM250 or 370 head?
« on: February 01, 2008, 04:51:22 pm »
Is Suzuki casting number ISZZ 241 an RM250 or 370 head? Other ?
Cheers.
Offline VMX Andrew
Re: RM250 or 370 head?
« Reply #1 on: February 01, 2008, 05:43:09 pm »
sorry to hijack this thread....but i was wondering if any of you know if i can fit an RM370 motor in an RM250 frame same year model..ive heard whispers it can be done but i thought id ask the pros first..reason is i know where there is a cheap 250 for sale and a 370 motor laying on the ground at a mates place...cheers :)
Quicksilver
« Reply #2 on: February 01, 2008, 05:50:35 pm »
I know wheres theirs a RM370 roller, so if you dont use that engine id certainly be very interested.
« Reply #3 on: February 01, 2008, 05:56:48 pm »
Wouldn't looking at the bore size make it obvious ???  ???
Quicksilver
« Reply #4 on: February 01, 2008, 05:58:43 pm »
Nope.  8)
Doc
« Reply #5 on: February 01, 2008, 08:04:12 pm »
measuring the bore size or head gasket ID should..the rm250's were 67mm bore the 370 were 77mm.
Andrew, yes the RM370A-B/400C will bolt into the RM250A/B/C frames..only mods you may need are the rear of the exhaust  ;)
Offline VMX Andrew
« Reply #6 on: February 01, 2008, 08:18:49 pm »
thanks doc for the good advice...your a champion...no better still your a LEGEND... 8)
Quicksilver
« Reply #7 on: February 01, 2008, 08:24:00 pm »
Thanks Doc..
It messures up at 82.98 maybe 400 or 465?  Its not the same to look at as the head that was on my old RM500.  The only info I have to go is "RM" written on the head with a paint pen. At least now I know its not 250 or 370.
Doc
« Reply #8 on: February 01, 2008, 08:48:49 pm »
 :D no legend Andrew, I have a 250C frame here that I'd planned my spare 400 going into when I get the time :P I best be absolutely sure before I state a definate..I'll go dig it out now and try it for size
80mm is 400C/N/T Quicky (if only suzuki had made a U model between the C and N could have been amusing) ;) the C has a round recessed gasket and the N and T have a surface gasket with 6 holes to fit over the studs.
Andrew, just double checked and it's all good in the engine/frame department..I doubt you'd even need to modify the rear exhaust mount as the 250 looks the same as the 370's.
« Last Edit: February 01, 2008, 09:20:27 pm by Doc »
Quicksilver
« Reply #9 on: February 01, 2008, 09:43:53 pm »
Thanks again Doc. Your a top man.  :)
I have an RM400 N or T head then. I'll be racing back out their in morning to see how much of that bike might still be laying about.
