Author Topic: That little muffler thingy  (Read 17289 times)
« on: March 01, 2011, 09:06:02 am »
The early KX 500's have a little alloy bracket that bolts between the frame and muffler.
I wanted to check how many models they fit but I can't look it up on Zedder if I don't know its name.
I have been searching online parts diagrams (CMSNL) for its name and or part No. but it’s not shown on any diagrams.
Can any one shed some light on this mysterious covert part?
ted
Re: That little muffler thingy
« Reply #1 on: March 01, 2011, 11:54:43 am »
Hi Geoff,  When i get home this arvo i will take a pic and post it up for you
Did you get the bits i sent?
Cheers Ted
« Reply #2 on: March 01, 2011, 12:43:50 pm »
Yes they did arrive thanks Ted, it felt like a 'licky dip' box when I went through it, many thanks.
I actually have a muffler thingy from an 87 KX 250 but I wanted to determine if it was the same as the 83 / 84 500.
Once I have a name or number I can run it through zedder.
I was surprised that it doesn't show up on any of the parts diagrams I looked at
I want to finalise a muffler jig for the 500's so i want to be sure the mount on the muffler is in the right place.
If you could note some measurements from yours would be useful, distance between holes and offset.
ted
« Reply #3 on: March 03, 2011, 08:39:19 pm »
RE : 1983 KX 500 A-1 muffler bracket
Hi Geoff...The reason you can`t find the bracket because it was never there in the first place according to the parts catalogue
The pipe on mine was built by the late Geoff Worrall and is running a DG muffler
Hope this helps
Offline Hardo
« Reply #4 on: March 04, 2011, 11:41:48 am »
It's found on the "FENDERS" diagram on the 83 250 schematic... maybe same for the 500?
HTH ...
« Reply #5 on: March 04, 2011, 11:50:58 am »
fantastic finish and detail on your Bike TED.
Offline Stevo17
« Reply #6 on: March 04, 2011, 11:59:03 am »
Hi Geoff, you can borrow mine if you want to make a copy.  It looks the same on my 84 250 & 500, plus it looks the same as the one on my 86 KX500 cheers steve
ted
« Reply #7 on: March 04, 2011, 12:21:52 pm »
The parts pic of the muffler came straight out of the original July 1982 Kawasaki Heavy Industries Ltd parts book that came with the bike...so i would assume that it`s a given
Thanks Hoony....There are others that disagree with you and me though
« Reply #8 on: March 04, 2011, 12:26:27 pm »
They can have their opinion, even if that opinion is wrong  ;)
« Reply #9 on: March 04, 2011, 10:01:21 pm »
Thanks guys, this is boring detective work compared to carbon dating a Bultaco, but we’re getting there.
Yes Hardo, found it on the mudguard schematic,
I had only looked on the muffler and frame schematics.
I thought it odd that this part wasn’t shown despite being on several models.
So it’s called a Muffler stay
Part # = 35011-1154
Part Description = MUFFLER STAY
Model Count = 4
KX250-C1 83 250 KX250 MOTOCROSS
KX250-C2 84 250 KX250 MOTOCROSS
KX500-A1 83 500 KX500 MOTOCROSS
KX500-A2 84 500 KX500 MOTOCROSS
It comes up as a different part No to my 87 model, which is different to the 86 model, which is different again to the 85 model!!!!
Thanks for the offer of a loaner but if someone can supply me these dimensions that should be all I need.
It may also be handy if someone can confirm the distance between the 2 mounting holes on the muffler too.
ted
« Reply #10 on: March 05, 2011, 02:03:39 pm »
85mm hole centre to hole centre
15mm to 18mm offset ...inside to outside..as drawn
After you found that bracket in the Fender section you would assume they wouldn`t put the lifejackets under the deck chairs on the ships they build..hehe
« Last Edit: March 05, 2011, 02:12:12 pm by ted »
« Reply #11 on: March 06, 2011, 06:45:56 pm »
Thanks for that Ted.
For the record the...
Part # = 35011-1322
Model Count = 2
KX250-E1 87 250 KX250 MOTOCROSS
KX500-C1 87 500 KX500 MOTOCROSS
is 66mm Eye to Eye and 10mm offset.
One last thing...
Can anyone confrim this measurement for the 83 / 84 500?
I was given the measurement of 125mm many years ago but I suspect it's not correct
Offline Stevo17
« Reply #12 on: March 06, 2011, 07:16:06 pm »
Hi Geoff, that DEP muffler on my 84 KX500 measures 140mm.  The muffler is stamped KX500 84-87
The Answer muffler on my 84 KX250 measures 135mm
ted
« Reply #13 on: March 06, 2011, 09:18:39 pm »
LET YOU KNOW TOMORROW
Offline Hardo
« Reply #14 on: March 15, 2011, 10:44:45 am »
Hey Geoff, are you planning on producing these little "Muffler Thingy's" ?
If so, I would like to buy one from you ...
