Author Topic: RM125 swing-arm bearings?  (Read 2103 times)
Offline Grunter215
« on: February 23, 2011, 08:43:08 pm »
Need swing-arm bearing kit for RM125N/T, whats the best one to get??  Cheers.
DR
Re: RM125 swing-arm bearings?
« Reply #1 on: February 27, 2011, 08:21:43 am »
215, I don't think Pivot Works make a kit for the early RM's but All Balls do. So far as I can tell the genuine parts are still available from Suzuki. If you wish to try a bearing supplier for the bearings the size is 17X24X20mm but the spacers would best sourced from Suzuki. If you wish to try All Balls the kit number is 28-1102.
https://www.allballsracing.com/28-1102.html
Genuine Bearing number 09263-17027 (x2)
Genuine Spacer number 61251-40200 (x2)
Offline kitakitsune
« Reply #2 on: March 01, 2011, 09:49:49 pm »
G'day kiwi215,
                    my allballs kit did not come with outer bushes. Just needle bearings, inner bushes and end caps. They only lasted 3 rides and seized. 2nd ride was very muddy with a high pressure wash before 3rd ride. Why they didn't include the outer bush is beyond me for the price. I purchased genuine suzuki swingarm axle,needle bearings, inner bushes, outer bushes [used the allballs end-caps] for  $89. from
"parts pit stop.com" in the U.S. A brand new genuine ignition coil was $69. Postage was about $50 - much better than "bike bandit.com" who wanted about $130 postage. Check them out, there are still heaps of genuine parts available for the old RM's there.
Cheers Kitakitsune.
Go no-where in your mind, and
you are now-here.
