Author Topic: Fox factory shocks  (Read 3738 times)
TM BILL
Fox factory shocks
« on: February 17, 2011, 02:23:25 pm »
Can somone please tell me what pressure i should run in Fox factory shocks thanks .
Offline allan55
Re: Fox factory shocks
« Reply #1 on: February 17, 2011, 03:59:54 pm »
Fox factory shox manual states 200 psi (air or nitrogen).
090
« Reply #2 on: February 17, 2011, 06:23:47 pm »
It actually depends on you weight and ability as well as preference. I would start around 150psi. 200 is up there. Best bet is to buy a copy of the manual off Thor Lawson .
TM BILL
« Reply #3 on: February 17, 2011, 06:26:52 pm »
Thanks for that  :) i have a manual for the air shocks  :) but not for the spring type, i will order one thanks .
« Reply #4 on: February 17, 2011, 07:10:39 pm »
I put 10 bar (145psi) in mine, the same as Ohlins shocks run.
« Reply #5 on: February 17, 2011, 07:52:15 pm »
Bill try this .     Air shox
                      Online calculator
      http://ltthor.home.comcast.net/~ltthor/forsale.html
« Last Edit: February 17, 2011, 07:54:20 pm by oldfart »
« Reply #6 on: February 18, 2011, 05:54:38 pm »
By the sounds of it he means these http://ltthor.home.comcast.net/~ltthor/FFS.html not airshocks
TM BILL
« Reply #7 on: February 18, 2011, 08:22:11 pm »
Thats the buggers  :) iv'e got a set of remotes and a set of piggy backs  :) 150 psi works great thanks .
