Author Topic: Dt1 heads 68-71 same as Dt1 heads 72 ?  (Read 3107 times)
« on: January 29, 2008, 11:13:23 pm »
are Dt1 heads 68-71 same as Dt1 heads 72 ? not the 2mx, just the DT1F
they all look the same to me, so why do folk list them as pre 71 only ? surely the are the same fitmanet and squishes or are the pre 71 units piston port and have different cones ?
Re: Dt1 heads 68-71 same as Dt1 heads 72 ?
« Reply #1 on: January 30, 2008, 09:37:38 am »
The early DT1 heads and the later heads have different spark plug placement and combustion chamber volume. Perhaps they want the earlier heads to be legal in pre 70. I don't know which is better as I've never run a stock head.
« Reply #2 on: January 30, 2008, 12:27:03 pm »
Dunno how it applies to a DT1/DT2, but an AT2 (reed valve) head on an AT1 (piston port) gives you too much compression and it pings like a mofo after about 5~10 minutes.
I believe that the same is true for the CT1/CT2 - so my assumption is that it's also the same for the DT1/DT2.
« Reply #3 on: January 30, 2008, 02:06:48 pm »
but a say dt1 reed would be ok on the piston port ? less or same comp and cc ?
« Reply #4 on: January 30, 2008, 02:09:18 pm »
well i looking at weather this unit would suit my DT1F flat track project and i got confused when he dropped the word, 68-71  they seem to be the same to me ?
just wanted to save the $100 if it wasnt going to fit up.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290201417127&ssPageName=ADME:X:RTQ:MOTORS:1123
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #5 on: January 30, 2008, 02:20:57 pm »
if ya can get it for a good price freaky,
BUY IT!
if it don't work you should be able to onsell a webco with no drama's
to me, it looks the goods...
"flat bickie"
« Reply #6 on: January 30, 2008, 02:44:36 pm »
soz.... didnt get a positive response before item ended. always another one out there. :O)
but some feedback would be good so we have the heads up early on the compatibilty, and thus be informed on the differances, if any.
