Author Topic: ktm600 rotax  (Read 2347 times)
Offline gra1961
ktm600 rotax
« on: February 16, 2011, 08:29:55 pm »
my motor has had the balance shaft removed (previous owner) when i was checking the timing beit marks today when  i removed the screw in the lower clutch cover to lock it at tdc about 100 ml of oil drainrd out.should i blank off the hole in the crank case where the balance shaft used to live?
Re: ktm600 rotax
« Reply #1 on: February 17, 2011, 07:21:17 am »
Hmm You dont need an oil filled cavity that dose nothing. So I would say Yes but I dont know these motors well enough.
