Author Topic: carb specs  (Read 2381 times)
Offline shorelinemc
  • life sucks&then you die
carb specs
« on: February 15, 2011, 06:45:36 pm »
any one with a tt500 with a 38mm mikuni what jetting,needle etc are you running want to check what hatricks have given me
Offline curly001
Re: carb specs
« Reply #1 on: February 17, 2011, 10:15:03 am »
I,m running a 36mm mikuni and these are my specs. Was dyno'ed by Carl Batey of Caferacer.com.au did story on 500 motor for VMX mag.
Slide 2.5
Jet(needle) P2(188)
Needle P2(188) clip on bottom slot with an additional shim
Pilot 35
Main 230
There are same rough spec's on 38mm on the SR500 forum also
Curly
