Author Topic: Motoplat HV Ignition Coils - Red Lead vs Black Lead?  (Read 2956 times)
Offline PEZBerq
  • Brisbane
« on: February 12, 2011, 07:20:52 pm »
Any Motoplat gurus out there know what the deal is with the Motoplat HT coils - red lead models vs black lead models ?  I have read that you can't interchange them and was wondering what the difference between the two types is  ??? ???. Thanks   :)
montynut
Re: Motoplat HV Ignition Coils - Red Lead vs Black Lead?
« Reply #1 on: February 13, 2011, 06:38:29 am »
The black lead coils are just that a simple ignition coil.
The red lead coils have some of the electronics located in the coil. There is a transistor, capacitor and I beleive an SCR located in the red lead coils while the black lead systems have those components located in the stator.
I would assume (there is that word) these components where moved to the coil for better cooling.
The coils are interchangable in so far as you can use a red lead coil on all systems but a black lead coil is only suitable for a system with the electronic components located in the stator as without those conponents the system will not work.
Unfortunately I do not believe that if the transistor, capacitor and SCR fails in the 'black lead' stator you can not just replace the black lead coil with a red lead coil. Life is never that simple :'(
Offline PEZBerq
  • Brisbane
« Reply #2 on: February 13, 2011, 10:23:39 am »
Ah ha  :D :D Thanks montynut I knew someone out there would have the good oil.  Mucho gracias amigo ;D ;D
