Author Topic: TM/RM125 project  (Read 19420 times)
0 Members and 5 Guests are viewing this topic.
Doc
TM/RM125 project
« on: January 29, 2008, 10:38:08 am »
Here's a few pics of my RM125S powered TM125 project. I'll try to post more pics as time goes by. Most parts are now here or on their way so hopefully it can be finished for Coff's dirt track. It's build entirely from bits and pieces with the most complete item obtained being the basic engine.
This is how it started. A rusty frame and left over RM125S tank.
I collected 'mainly used' parts from all over the world mostly through eBay although some were also made available by generous forum members and like minded vmx friends. Bearings, seals and gaskets are being replaced as I go.
The engine came as you see it less the polished cover. Seems like a good motor but I'll hop in and replace rings, top end bearing, gaskets and seals then match ports and gaskets more accurately before I run it. A nos clutch kit is also awaiting fitment.
I like to piece the bike together up to about 90% and then I pull it back down for the tidy up.The front engine mount plates I pondered buying but instead made a pair from 3mm 6061 T6 aluminium plate in about 20 minutes using a stock TM mount as my template.
I thought white guards would look nice. Again used items will simply be cleaned up and sprayed and these will do the job as good as the next. The tank was on to give me an idea of the colours but the RMS tank is in getting a coat of pearl yellow as this is typed.
The forks fitted in this picture are 33mm TS185er units in reamed TM clamps. I could not find era axle under type lowers to suit so the triples have again been reamed this time out to 35mm which allows more options. The frame I'd started to rub back.
Here is the frame ready for the colour. I never undercoat frame since I have learnt it makes very little difference in application and actually looks worse when it gets chipped and scratched due to the undercoat showing. I'm a little picky with shit like this and besides, they aren't primed from the factory  ;) Took about  12 hours to get the frame to this point and yes, sand blasting would have made life so much easier but I tend to do them by hand given a little spare time here and there.
Here she is painted. I didn't want it to look anything like silver frost so I lashed and spent $30 colouring it pearl platinum followed by a few coats of clear. This pic actually has the metalflake reflecting making it appear more silver than it really is. You may notice no coil mounts, I intend to move this to a much lower position tucked in beside the airfilter. The frame/swingarm are '75M model by the way.
Coming together now this is the front end that will remain. Tried and proven '75 35mm XL250 motosport units. Front wheel is also XL250 with a nice sized stopper. Rear wheel is a solid mount TS185 with alloy rim and the rear shocks are 1995 TS185 simply because I like them, they are a little shorter but they work well enough for me. The alloy sprocket makes a big reduction in unsprung weight when compared to steel of equal size. Again ebay supplied this sprocket for about $20 landed.
she won't be a show bike but it will be a little different and it should fairly honk and suit my short arse a little better than the full blown long legged 125S..it's being built to comply with pre78 regs in case you were wondering..updates to follow..
« Last Edit: January 29, 2008, 10:48:39 am by Doc »
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: TM/RM125 project
« Reply #1 on: January 29, 2008, 01:00:58 pm »
very nice Doc,
does that pearl platinum come in a can?
"flat bickie"
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
« Reply #2 on: January 29, 2008, 01:48:31 pm »
Nice stuff DOC, do you have an inner fender? I found a used RM125M in amongst some TM bits.
Ban BLACK rims NOW
Doc
« Reply #3 on: January 29, 2008, 03:07:48 pm »
Thanks and yes and yes  ;)
Vandy yes, (spray can is how I paint everything except the tank :P) the pearl platinum comes in a can. Part Plus I think it was..from supercheap but not the cheap stuff
and yes Cyclegod, I have an inner rear thanks, I picked one up in the US for $14..it was listed as TS185 but I had it sent over with quite a few bits so the postage was negligable ;) Think the only bit I really need now is a nice rolled edge white front plate and top rear guard/frame mount and front sprocket cover. All pretty readily available. It'll be another sub $500 special (not including labour, which of course is free) Add that in and I suppose around $1500 would be a more realistic figure.
« Last Edit: January 29, 2008, 03:12:54 pm by Doc »
Offline jimson
  • Sanctuary point N.S.W
« Reply #4 on: January 29, 2008, 08:57:57 pm »
Looks good Doc  8)  I'm trying to build up a TS 185 1973 from bits n pieces I  have in the shed where did you get the front guard from and how much was it.I like your projects as they are more hands on then just cash flow. jimson
Offline dodgee
« Reply #5 on: January 29, 2008, 09:50:46 pm »
cyclegod.
i am looking for a inner rear guard for a rm let me know what you want for it.
dodgee
Offline cyclegod
  • Sunny PERTH W.A
« Reply #6 on: January 29, 2008, 10:04:08 pm »
cyclegod.
dodgee
PM sent
Ban BLACK rims NOW
Doc
« Reply #7 on: January 30, 2008, 06:03:58 am »
Ta Jimson the front guard is an old RM/TM genuine front guard. I merely painted it with flat white then buffed it lightly with a piece of steel wool to give a smooth satin finish when dry. Rear will be done the same... I gave the bottom end a quick polish and fitted the motor in the frame last night but the result looks pox for want of a better adjective. I'll be pulling it back out to splash a bit of satin black over it before refitting me thinks. I had to sand the engine anyway and the polishing was just an extension of this sanding (in other words I got carried away once I saw bright shiney alloy :P) that happens sometimes  ::)
« Last Edit: January 30, 2008, 07:49:21 am by Doc »
« Reply #8 on: January 30, 2008, 04:48:27 pm »
Too much bling bling  :D
YSS
« Reply #9 on: January 30, 2008, 04:58:15 pm »
Hi Doc , can you give us run down please on that polishing  ,of how you did it and whats involved.
It looks great .
« Reply #10 on: January 30, 2008, 06:27:18 pm »
I bet you he tells us no power tools were invovled and all done by hand  ;)   good old elbow grease
Doc
« Reply #11 on: January 30, 2008, 06:48:52 pm »
 :D YSS, oldfart has it in a nutshell. A small screwdriver for those hard to reach bits, 2 sheets of 400 wet and dry to wrap around the screwdriver or fingers depending on area to be sanded, about 2 litres of H2O and a rainy day. This poor man's mill finish I find pretty easy and easy on the eyes but the mirror finish stuff and I can't do. Ya need a machine for that  ;) she's all black again now but it looks better in the frame ::)
going to remove the top end hence I haven't bothered with that yet only to know the outside fins have flaws that will not polish out (by hand) so it'll be painted too ;)
« Last Edit: January 30, 2008, 10:21:06 pm by Doc »
Offline cyclegod
  • Sunny PERTH W.A
« Reply #12 on: January 30, 2008, 07:06:13 pm »
Ban BLACK rims NOW
Doc
« Reply #13 on: January 30, 2008, 07:17:58 pm »
 :-\ mmmm..it's kinda okay but over priced for me :D just can't get into the TC's and duel range gearboxes..I've enough 125's after I complete this one (tm125,tm/rm125,ts125mx,rm125a/b) so I'll move up to a 250 for the next project  ;D
TM BILL
« Reply #14 on: January 31, 2008, 05:45:29 pm »
Those TCs would be a great but for the TM RMS restorer , Many parts will interchange and the cases on those TC 125 A models are great replacments for worn out RMS cases .
The forks go great in a TM 125 as do the hubs ( solid rear )
Crank is a TM or S replacment , Clutch and Primary gear will work in TM to.
If you are building a TM or RM M or S 125 dont over look the humble TC 125 A as a donor.
Shipping to much to send here as i already have about a dozen of these buggers  :D but may help somone out.
