Suzuki
numbers for rmor PE
All
Topic: numbers for rmor PE (Read 9430 times)
Freakshow
Superstar
numbers for rmor PE
February 08, 2011, 03:06:52 pm »
have a 250 motor but it has factory blank stamping ( no engine number)
suspect its a replacemtn blank but anyway the cast number is iszz214R rod is stamped S-2 and the barrel is 10 hole.
So its a 250cc RM or PE form 80 "s does anyone no for sure which.
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
vmx42
Re: numbers for rmor PE
February 08, 2011, 03:15:48 pm »
Hey Freaky,
A quick way to determine if it is RM or PE would be to look at the ignition…
VMX42
Also I don't think the RM had the cutout in the cylinder fins for the rubber sound deadening blocks…
Freakshow
Superstar
February 08, 2011, 04:03:40 pm »
no ign. its the bottom end im more deterined to confirm what it is before i sell it., the barrel etc may well be PE etc, but i dont want to short change peeps on the bottom end.
vmx42
February 08, 2011, 04:18:27 pm »
that makes it much harder, good luck!!
Freakshow
Superstar
February 08, 2011, 04:27:16 pm »
Bit dusty but you get the idea
also found this ign which looks suzuki too
car to id electric and price it ??
ranchak
February 08, 2011, 04:38:38 pm »
The clutch cover looks like a PE250C.
February 08, 2011, 04:48:43 pm »
1977 or 1978 Pe or RM .....look on cases @ flat edge by kick start spine - should reveal all.
I will put my hand up for clutch cover
Last Edit: February 08, 2011, 04:50:51 pm by oldfart
Freakshow
Superstar
Reply #7 on:
February 08, 2011, 04:51:18 pm »
what am i looking for there ? stew.
remebr its a factory blank case ( no engine numbers)
Freakshow
Superstar
Reply #8 on:
February 08, 2011, 05:01:38 pm »
this is a spare cover/clutch i have also Stew, no idea what thats off either ?
this one any good to you
frostype400
Reply #9 on:
February 08, 2011, 05:03:49 pm »
that is a 80-82 pe250-400 clutch cover by the look of it freaky.
1971 tm400 and PE's
Reply #10 on:
February 08, 2011, 05:11:51 pm »
Note the difference in clutch drive hub 77/78 has no flat base 1980-81-82 has
Freakshow
Superstar
Reply #11 on:
February 08, 2011, 05:13:37 pm »
So no use to you ??
Freakshow
Superstar
Reply #12 on:
February 08, 2011, 05:15:00 pm »
i take it the clutch arm is relocated ? not on the cover like the TM style fitting then. ONLy PE or RM as well is this one ? say mag on it and has small weld inside.
Reply #13 on:
February 08, 2011, 05:18:26 pm »
Yes ... 1980 models moved clutch pivot in front of sprocket, hence no bracket on cover.
1977-78 250 clutch cover is what I want.
Freakshow
Superstar
Reply #14 on:
February 08, 2011, 05:27:01 pm »
little ign box ends in #1420, so is it a PE250 (77+) not sure on the stator etc but may or may not have been with it,
All
Suzuki
numbers for rmor PE
