Author Topic: Getting rockers back on the straight and narrow  (Read 2412 times)
« on: February 07, 2011, 03:47:50 pm »
Preparing a TT250 for HEAVEN races.  Just gave it nice new top end, then pulled the cam for quick look, to find surfaces worn and rough, same with rockers.  I can replace the cam with aftermarket, just wondering what to do with the rocker faces.  I'm not too worried about losing a bit of lift if i file them smooth (as the new cam comes with big chunks), but wondering if the surface will last.  Any views?
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Ban BLACK rims NOW
Offline shorelinemc
  • life sucks&then you die
Re: Getting rockers back on the straight and narrow
« Reply #2 on: February 07, 2011, 06:22:57 pm »
waggot cams can fix 02 66283795
« Reply #3 on: February 07, 2011, 06:54:57 pm »
You can metal spray them with tungsten powder and have them reground.
Curly3
« Reply #4 on: February 07, 2011, 08:52:44 pm »
If the rocker has lost its hardness they'll wear faster.
If you keep the clearance adjusted correctly you won't lose any lift, but you will have to check it more often.
