Author Topic: TS 250 Hop-up  (Read 16975 times)
DR
Re: TS 250 Hop-up
« Reply #15 on: February 06, 2011, 05:45:27 pm »
Yep Mark, I've only ever seen one other TS250 kit pipe for sale locally and I swooped. It was rooted, crushed and flattened but I spent a couple of days cutting it open and beating it back into shape. The guy who had the TS250 wreck for sale was hesitant to accept my offer of $50 and a good stock pipe as he thought I would be disappointed. I have b4 and after pics and I even amazed myself with my pathetic panel beating skills :) If you are thinking of selling they seem to go for around $200-$250 at an average and I am as usual interested in any of the TS model R/T kit items ;)
Offline JC
Re: TS 250 Hop-up
« Reply #16 on: February 06, 2011, 08:32:25 pm »
TM and TS non reed cyls will interchange (exeption being 1976 TS 250A cyl , different transfers and electrofusion bore ex factory  :o )
TS only has 2 transfers small intake port and non bridged smaller exhaust port.
TM 4 transfers big intake port and big bridged exhaust port.
I have a NOS TM 250 Cylinder , piston and rings for sale (no gudgeon or clips) and a used TM 250 head $Au 300.00 plus postage  ;)
Bill, are you sure the TM has 4 transfers?  I always tho't they only had 2 like the TS barrels, but I'm no suzuki guru.
DR
Re: TS 250 Hop-up
« Reply #17 on: February 06, 2011, 09:39:33 pm »
2 transfers with bridged inlet and bridged exhaust on the TM's.
2 transfers with bridged inlet and unbridged exhaust on both TS and RL250.
« Last Edit: February 06, 2011, 09:46:53 pm by Doc »
TM BILL
Re: TS 250 Hop-up
« Reply #18 on: February 07, 2011, 05:23:29 am »
Will post a pic of TM 250 cylinder   :)
TS 250 Cylinder
« Last Edit: February 07, 2011, 07:39:02 am by TM BILL »
Offline JC
Re: TS 250 Hop-up
« Reply #19 on: February 07, 2011, 07:44:20 am »
Thanks Bill,
Looks like the 74/75 TM barrell. Earlier TM barrels were 2 tranfers I believe.
DR
Re: TS 250 Hop-up
« Reply #20 on: February 07, 2011, 07:48:07 am »
Well thar ya go :) was thinking Bill's must be from the later model as all my TM barrels are of the type mentioned above. Bridged exhaust, bridged inlet and 2 transfers ;)
TM BILL
Re: TS 250 Hop-up
« Reply #21 on: February 07, 2011, 07:58:56 am »
Bugger and there was me thinking i had somthing special  ;D
Re: TS 250 Hop-up
« Reply #22 on: February 07, 2011, 11:51:28 am »
Does the base of the TM and TS cylinders match Bill? The angle out at the flange looks different?
The TS cylinder could be made into something very good.
DR
Re: TS 250 Hop-up
« Reply #23 on: February 07, 2011, 12:09:58 pm »
they all interchange Loz, the exhaust exit angle the only difference.
Offline JC
Re: TS 250 Hop-up
« Reply #24 on: February 07, 2011, 01:09:10 pm »
Its not an RH barrell is it Bill? ;)
Offline JC
Re: TS 250 Hop-up
« Reply #25 on: February 07, 2011, 01:19:14 pm »
Sorry guys
It's a 1972 model. I do have a 2nd hand TM top end, but it's already bored out to + 1.25mm. I may not get a +1.5 oversize so I'll have to re-sleeve. The (homemade) pipe also won't fit the TM barrel. Gear ratios are the same as the TM as I recall.
I'm a bit tight for time (race in 2 weeks) so I was looking to pep up the TS ports, stick on the 32mm TM carb and use it as an intermediate step.
Regards
David
David, I wouldn't be resleeving a +1.25 barrell. Wiseco make +1.5 & +2.0 pistons. I'd wait till I could find one of those. It'd be much cheaper.
If you want porting specs from back in the day, I have several mag articles. Typically they said raise the exh a couple of mms, lower the inlet (or cut the skirt) similarly, ramp the top of the piston adjacent to the transfers 1.5mm, widen the exh 7mm (but I wouldn't go wider than 49mm - 70% of bore). In general, aim for circa 180deg exh durat'n & circa 165 degs inlet. Use TM head & carb. Thats still pretty mild but should be a good starting point. I'm sure Lozza can do a lot better.
FWIW factory specs are as follows (from top of barrel):
Exh  TS 39mm  Kit Cyl 37mm
Tr    TS 53     Kit Cyl  52
In    TS 99     Kit cyl  103
The responsibilty for changes is all yours! I have no experience w TM/TS250 mods
« Last Edit: February 07, 2011, 05:19:45 pm by JC »
TM BILL
Re: TS 250 Hop-up
« Reply #26 on: February 07, 2011, 02:08:15 pm »
 ;D ;D ;D ;D  RH in this case right horrible  :D i want it gone  ;)
