Author Topic: 897 jawa speedway bike  (Read 12841 times)
Offline ian
« on: January 28, 2011, 08:03:42 pm »
selling speedway bike .its ready to ride any one wants info ring me on 0439374728 ian. can get to brisbane .
Offline ian
Re: 897 jawa speedway bike
« Reply #1 on: January 28, 2011, 08:10:25 pm »
sorry price is $3500 no offers thanks ian.
« Reply #2 on: January 31, 2011, 01:17:32 am »
Assume its an evo 4 valve, do you have the pogo front end, and do you know when the motor and rods/crank and so on was last replaced.
Offline ian
« Reply #3 on: January 31, 2011, 04:29:46 pm »
  no i don't have the pogo front end it's legal with the leading link front end .the engine i got the eng from nsw i pay $1500 it was pulled down its got a steel rod so its got new little end bush and big end bush pin and bearing .the main bearing have been replaced .the piston is first oversize  had it crack tested and ceramic coated .the head was in good nick reface the valves. and valve seats reseated and new springs . its got a new dellorto 34mm carby new exhaust pipe all new eng bolts seat and brackets. lz clutch and new hagon shock. new rear rim and spokes front is the old steel rim .thanks ian.
Offline ian
« Reply #4 on: February 02, 2011, 06:27:46 pm »
the motor was built last year its been ridden twice .
Offline ian
« Reply #5 on: March 05, 2011, 01:23:33 pm »
any offers real ones .thanks ian
« Reply #6 on: March 06, 2011, 01:07:22 am »
Are you selling any bits ? or do you have any spare rubber bands ?
Offline ian
« Reply #7 on: March 06, 2011, 04:46:27 pm »
i have some spare clutch plates four the bike. rubber bands chris barton what bits are you looking four
« Reply #8 on: March 06, 2011, 10:58:18 pm »
wouldnt mind a complet neb 6 pin or even parts for my 3 button.
Fenders, cut out switch, seat, pogo fork "H" section, actually anything really
also need bits for the 125 slider - see 'project freaky to the nats thread" for details of stuff that bike needs are listed there, seat, fenders rubber bands, clutch level and cable, throttle cable so on
« Reply #9 on: March 07, 2011, 06:44:35 am »
freaky
you need to buy new rubber bands you would of had them buy now if you ordred them from antig.speedway forks are way different to hagon forks. ians bike has the rubberbands as it is leading link but earlyer speedway forks have no intechangable parts with hagon type forks
jim
« Reply #10 on: March 07, 2011, 12:07:45 pm »
YOU told me the bands are the same as the ones on the front links of modern and that i needed 2 per side ????
i need the bands for the hagon type forks ?  make up your mind.
« Last Edit: March 07, 2011, 12:12:32 pm by Freakshow »
« Reply #11 on: March 07, 2011, 12:30:55 pm »
antig part no LF10 SUSPENSION BAND
ON PAGE
8
10
12
16
same band 1.35 pounds each + postage
under 10.00 pounds+shipping you will have 6 4 for the bike and 2 spare
yes ians bike has them too. modern speedway,grasstrack/longtrack and classic grasstrack not speedway
« Reply #12 on: March 07, 2011, 01:45:50 pm »
thats what i said and thats why i asked?????
there for the 125 slider.
you must not have read all of my post properly.
Offline ian
« Reply #13 on: March 07, 2011, 08:34:35 pm »
mate i got a old seat not banna seat just the short one .and a counter sharft i think its neb .as four the clutch cable you can ring john titman and ask four a venhill universal clutch cable g02-3-001 .comes with a few differnt fittings about $35 and make your own .that nuber is four a grass track cable .the outer is 1430 long .if you get one off these you can go to the motor bike shop and buy a lever to suit .the throttle cable any motor bike shop will make them .i run a 1/4 turn throttle from the bike shop and lever if one breaks i just go and get one off the shelf .cheap
