Marque Remarks
Yamaha
Dumb YZ electrics question - Kill Switches
Topic: Dumb YZ electrics question - Kill Switches (Read 2069 times)
Woody
A-Grade
Heaven #70
January 21, 2011, 09:25:02 pm »
I got a bit excited when I saw that you could still order an OEM kill switch for my YZ125G from boats.net (23X-83936-01-00), but was disappointed when I got it to see that it was updated with the later square red button type. Then I got onto the black round type but as you can see it has only a single wire.
Question is, can I make it work on my double wired YZ125G set up?
WANTED
1988/89 125 - CR KX YZ
IT200 stuff
CR250RD parts
LWC82PE
Superstar
Re: Dumb YZ electrics question - Kill Switches
January 21, 2011, 09:35:57 pm »
There should be a part of the switch that contacts the metal bracket so then all you need to do its feed an extra wire to it, attache a loop terminal and fix the loop terminal under the screw head.
Woody
A-Grade
Heaven #70
January 22, 2011, 09:25:42 pm »
thanks Leith, I'll give it a go when I get a chance and work it all out
WANTED
IT200 stuff
CR250RD parts
ted
January 26, 2011, 10:39:45 pm »
How`s the H going Woody....will we see it this year
Marque Remarks
Yamaha
