Author Topic: ktm600 rotax 4 stroke  (Read 11095 times)
Offline gra1961
« on: January 21, 2011, 08:04:12 am »
ive just got my 84 ktm600 4 stroke rotax going but to get it to idle the idle screw has to be turned in all the way and have the choke on a little bit other wise it pops a little at the exhaust.bike starts easily and runs clean like this.im thinking maybe cam timing?any clues.(easier to post this than to go down stairs and check it out)
Re: ktm600 rotax 4 stroke
« Reply #1 on: January 21, 2011, 08:35:32 am »
Sounds like it's running lean, checked for air leaks? changed the jetting?, fitted a different exhaust?
« Reply #2 on: January 21, 2011, 08:49:27 am »
Air leak between carby and cylinder or there is a blockage in the carby somewhere. I had this problem on a kawasaki quad once, the bike would not run without choke. Took the carby apart, blew it out and then it was fine.
« Last Edit: January 21, 2011, 12:52:22 pm by LWC82PE »
« Reply #3 on: January 21, 2011, 09:32:15 am »
You need the correct cam belt on these , there is a new one thats 1/2 a tooth out and gives problems.
Did you replace the belt?
Offline mustanggrahame
« Reply #4 on: January 21, 2011, 12:18:00 pm »
My TT600 had the same symptoms. It hadn't been running for 4 years and even though I had dismantled the carbys, I had to do it again and really clean the pilot jetting and tube with a sharp needle. The tube had green crusty stuff in it. Worked perfectly after that. This maybe your problem
Cheers, Grahame
« Reply #5 on: January 21, 2011, 12:58:51 pm »
Yeah if the bike has not been running for years, there is bound to be blockages in the carby jets and orifices due to stale fuel. Old fuel causes heaps of problems these days, especially premium because it goes stale pretty quickly. You really gotta be riding the bike almost once a week so the fuel doesnt go off in the bowl. It can actually grows a green algy stuff. I will never forget the time i stripped a set of XS750 carbs and they were full of a dark green algy growing inside them, it looked like the stuff you would see in a creek or fish pond. It was really really bad and smelt really strong and bad and the smell hung around for a few days. That was the worst one i had ever come across. Before Xmas i put a new head gasket on a Trident which had not been ridden for several months because of the head leak. Well after fixing that, the bike would not run on the middle cylinder so when i took the carbies off the middle one was all blocked up with some sort of white stuff from fuel that had gone off. Before that it was gutless and seemed to only do about 80km's but after cleaning it out it was much more like the rocket it should be like and was so much better when runnning on 3 cylinders.
« Last Edit: January 21, 2011, 01:01:56 pm by LWC82PE »
Offline gra1961
« Reply #6 on: January 21, 2011, 02:16:09 pm »
have fitted a new timing belt that i got from bert floods,might clean the carby again with my glasses on this time and less beers.thanks for your input fellas
Offline Canam370
« Reply #7 on: January 21, 2011, 04:21:47 pm »
Alright, I'll tell you the secret. That green-hard residue can't be removed unless scraped off. Solvents, nothing. But, if you put the jets etc in boiling water it will remove it or at worst soften it some to make removal a LOT easier. Makes the experience a bit nicer. ;)
Offline supermotomc
  • SWM ktm, dealer mechanic 1977-1995
« Reply #8 on: January 26, 2017, 12:44:30 pm »
if you do read this dump the lot in LEED lemonade and leave it for two day then smile and wipe!!
« Reply #9 on: January 26, 2017, 02:11:53 pm »
if sugary acid dissolves it ...ethanol residues? I had a dr 350 that had cement in the pilot, totally unmoveable
« Reply #10 on: January 26, 2017, 09:52:19 pm »
 "I had a dr 350 that had cement in the pilot"   Could be a story there................ :o
Offline gra1961
« Reply #11 on: January 27, 2017, 07:51:56 am »
gee that was along time ago,it ended up being a crack in the inlet manifold rubber sucking air.
« Reply #12 on: January 27, 2017, 08:18:55 am »
cement in the pilot? hmm, wonder where the jet went??
« Reply #13 on: January 27, 2017, 10:49:02 am »
Offline KTM47
« Reply #14 on: January 27, 2017, 01:14:53 pm »
If leeds lemonaide cleans it coke a cola probably will too.  have you seen what it does to a two cent coin.
MAICOS RULE DESPITE THE FOOLS
