Author Topic: How much metal can you remove from a piston top?  (Read 2144 times)
Offline MX?
    • Classic Bike Forum
« on: January 19, 2011, 06:04:50 pm »
I need to deepen the valve cutaways in my XL piston. Assuming I work out how much meat I have in the crown of the piston is there some kind of "safe" thickness of material to leave?
Curly3
Re: How much metal can you remove from a piston top?
« Reply #1 on: January 19, 2011, 06:32:04 pm »
Ckeck the standard clearence and take as little as is needed, don't forget you'll reduce the compression.
Offline vmx42
« Reply #2 on: January 20, 2011, 10:39:39 am »
Hey MX,
A bit of a chicken and egg senario here [IMHO].
I would first measure the clearance between the valves and the piston [using putty and sliver solder]. After careful measurement if there isn't enough clearance I would measure the thickness of the piston crown.
Other more knowledgeable OzVMXers can probably tell you the minimum clearance numbers for your engine. But I think you need to know the extent of the problem first…
Good luck
VMX42
Offline noisy toy
« Reply #3 on: January 20, 2011, 04:55:57 pm »
Maybe go to the wreckers and get an old piston and drill a hole in it. I have a buggered xt600 Wiseco piston if yours is Wiseco, I can drill a hole through the crown and measure if you want.
