Author Topic: 35mm Betor Forks  (Read 7974 times)
Offline sudman
35mm Betor Forks
« on: January 19, 2011, 11:12:42 am »
I have a set of non leading axle 35mm Betor forks with the self bleeding top caps, they are 850mm from top to axle centre.
I have just replaced the seals & would like to know what grade & volume of oil is correct (I got 170 mils out of each leg when I drained them)
Offline David Lahey
Re: 35mm Betor Forks
« Reply #1 on: January 19, 2011, 10:24:36 pm »
If ever in doubt, set fork oil level to 125mm below the top end of the tubes with the forks fully compressed and springs removed.
If you want more specific info you will need to say what sort of 35mm in-line axle Betors they are and what sort of riding they will be used for
previous pseudonym feetupfun
Offline sudman
« Reply #2 on: January 20, 2011, 06:48:22 am »
Thanks I don't know what model they are as they have no markings other than Betor on them, they are fitted to my C & J Honda XL350 Baja bike which is about 1975 model & it's used for mx. Cheers
Offline David Lahey
« Reply #3 on: January 21, 2011, 08:21:41 pm »
Sounds like they will be hammered a bit harder than when they were on the Pursang I'm guessing they came from. I would first off try modern 20wt fork oil. If the damping is too light with 20wt fork oil, try a lightweight manual car gearbox oil like Castrol VMX80.
« Reply #4 on: January 21, 2011, 10:44:56 pm »
I put 15w and a YSS valve kit in. Very happy with result. I weigh 95kg if it helps. Cheers Jerry
Offline Canam370
« Reply #5 on: January 21, 2011, 10:58:37 pm »
I was asked to put 30wt into the forks for the Nats ride. I used car running oil - it was the only straight 30wt I could find. Worked fine.
Offline sudman
« Reply #6 on: January 22, 2011, 08:20:31 am »
Thanks guys the forks were new with the bike as C & J offered Betor forks as an option with heavy springs, found this on the Penton owners forum, what do you think?
Here's the short version of the article-just the facts ma'am!
To keep oil contained in the piston area requires a simple modification.Take a piece of tubing the same o.d. as the damper rod.The added piece of tubing should be 1 inch (approx.)long.Weld one end completely shut.Next,carefully weld the finished "cap" onto the top of the damper assy.(above piston).Heliarc works best for this.Grind off any excess weld because this cap has to fit up inside the fork spring.After welding,drill four 1/4" holes in the sides of the cap (above the weld) at 90 degree intervals.This mod. keeps oil always available to the damper piston to minimize topping and bottoming out.
Another problem inherent in betor forks is oil leaking out the breather holes in the fork caps.The fork mod. previously described will also cure this problem.
Fork Filling-#1-Remove fork caps and pull out the springs.#2-Drain out the old oil.#3-Clean out excess oil gathered inside fork tubes and sliders by replacing drain plugs,then fill each tube with solvent (gas can be ued but solvent is better)Let solvent sit for 5-10 minutes.#4-Drain solvent blow out excess with air gun.#5-Clean excess oil off fork springs.#6- replace drain plugs.#7-Leave front wheel off,but slide axle thru to keep forks even.#8-Rock bike forward on stand so bottom of forks touch the ground.(In this position the forks are nearly vertical and can be filled more accurately.)#9-Pour in oil(do NOT use std. capacity!)#10-Use a flashlite to sight down each tube.Fill each tube until oil just covers the flat above the piston (the spring sits on this flat).#11-Place your foot on the axle,grab the handlebars and gently pump the forks up and downThis will displace all the trapped air in the damping system and cause the oil level to drop slightly.#12-Keep your foot on the axle and pull the forks up as far as they will go.Make sure you can feel the damping rod bumping against the topping spring,then repeat step #10...#13-Repeat steps #11 and #12.Continue to repeat until the oil level remains constant after pumping.Final oil level should be as described in step #10-(covers the flat just above the piston)#14-Tip the bike back up level on its stand and slip the springs into place,insert the caps and you've got it-matched forks.one last suggestion-you can keep the fork caps operating(breathing)better by injecting a squirt of wd-40 in the breather hole each time you change your fork oil.Before re-assembling let the caps sit for a while so the excess wd40 will drain off.
OK-THATS IT!Keep in mind this is a period modification taken out of a 1975 magazine so don't expect cartridge fork performance from your 7" travel Betors.And for safety reasons always use the factory service manual for disassebly/assembly,replace any worn parts,and if you don't feel confident performing this,have a qualified technician do it for you.Have a good welder do that part of the mods. too,if you have doubts about your welding skills.I condensed this article to save space but believe i've included all important steps-if you have doubts email me and i'll go over it(the article) with you.Legal waiver -do this at your own risk!I'm not responsible if you screw up the procedure and your forks come apart over the big Double!!!!!!!Hope this helps some of you Betor guys dial in their forks...
