Author Topic: ts250x front wheel  (Read 3448 times)
Offline frostype400
ts250x front wheel
« on: January 16, 2011, 04:10:28 pm »
I am after a ts 250 front wheel and front axle or if some one knows a wheel that is the same maybe an rm? I'd like to know if some thing else would work I have some ts250x forks discs and a caliper if I can use another wheel that would be handy, thanks alot Michael.
1971 tm400 and PE's
Offline wmc83
Re: ts250x front wheel
« Reply #1 on: January 16, 2011, 05:09:27 pm »
I have a 89 rmx front wheel if it's any use to you.
« Reply #2 on: January 16, 2011, 05:24:57 pm »
I've got a whole TS250X that's just ben made redundant by the DT200R I bought today...
Offline frostype400
« Reply #3 on: January 16, 2011, 05:50:24 pm »
Yeah what do you mean by redundant would you part it? I am using the ts front end for my pe400 project that I want a front disc for and would still be vinduro eligable because the forks I have and caliper are 1984. :)
1971 tm400 and PE's
« Reply #4 on: January 16, 2011, 08:10:39 pm »
I know where there is a whole TS for sale
Offline frostype400
« Reply #5 on: January 16, 2011, 08:34:51 pm »
Yeah I really just want the front wheel and axle if possible that someone is parting one I like the idea that it is a suzuki front end on my project pe and I will still be able to run the same headlight the forks are only 38mm not USD forks I don't think that they suit old bikes even though the performance is better. :)
1971 tm400 and PE's
« Reply #6 on: January 16, 2011, 09:45:12 pm »
Im looking for a master cylinder and caliper. I can wait for a wheel though.
« Reply #7 on: January 17, 2011, 09:54:42 pm »
How much are the bits worth to each of you?
If the money is right, it could tip the balance in favour of wrecking the bike - don't think that means that I'll want a million dollars though...
Offline frostype400
« Reply #8 on: January 17, 2011, 10:11:07 pm »
There is a ts250x wheel on ebay but it is $150 I am cool with that they aren't as easy as other wheels to come by but I still won't have an axle I was thinking of an rm wheel but I kind of want a speedo drive too.
1971 tm400 and PE's
« Reply #9 on: January 17, 2011, 10:13:21 pm »
what model is yours Nathan? it would be a shame to hack it up for 3 parts though. It looked like a fairly good starting point from the photo i saw.
« Reply #10 on: January 17, 2011, 10:16:38 pm »
Mine's an 88, Leith. AFAIK, the front ends never changed.
Michael, I'd definitely do better than $150 for wheel & axle.
Offline frostype400
« Reply #11 on: January 17, 2011, 10:25:43 pm »
Only if you want to part it Nathan don't feel obliged to part it for one bit to sell I have ts250 stuff in my roof too that is something I should get rid of I won't use it or the frame in my back yard.
What I was thinking of doing is I have a pe400 roller and it would be nice to have one that pulls up quick the 82-84 pe175 trees are 38mm and will take the same headlight and the ts forks are 38mm I didn't want some USD's I reckon although they work great they look wrong the 38 ts forks look like perhaps they could have came out on the PE they won't look out of place and are the right length. :)
1971 tm400 and PE's
« Reply #12 on: January 17, 2011, 10:30:57 pm »
I think the calipers/master cylinders are different, i know the forks are. I will have to research it .
Offline roy dale
« Reply #13 on: January 24, 2011, 10:47:24 am »
Hi mate
do you still need a front wheel
you can get me on  [email protected]   www.japbikespares.com   0410644974
Offline frostype400
« Reply #14 on: January 24, 2011, 07:55:49 pm »
Yes I still need a wheel email sent, thanks Michael.
1971 tm400 and PE's
