Author Topic: PDF parts catalogue for KTM 495  (Read 4645 times)
Offline IT490K1983
« on: January 14, 2011, 10:19:22 pm »
Does anyone know if there is a downloadable PDF based parts catalogue on the web for an 82 495? Thanks in advance for any info.
Re: PDF parts catalogue for KTM 495
« Reply #1 on: January 19, 2011, 08:55:58 am »
Maybe try the 495 web site there is one just for 495 owners.
Offline Tossa
« Reply #2 on: January 23, 2011, 03:11:40 pm »
http://www.ktm495.mxbikes.com/
1979 Husqvarna WR250
1974 Husqvarna MAG CR250
« Reply #3 on: January 23, 2011, 06:40:26 pm »
Hey Tossa how's the 390 going ?
Offline Tossa
« Reply #4 on: January 24, 2011, 01:49:53 pm »
Haven't had time to do any work on it due to several things, injuries and moving house.  About to rebuild the motor again as, the thread on the flywheel is shot, so taking the crank out and replacing with a recon one.  It has run for 1minute, but thought better of taking it for a ride.  Hopefully will remove the motor from the frame next week and have it up and going by the end of Feb.  yeah i know only dreaming.  maybe you can help, the beast has amazing compression is there any way of fitting a decompression device such as the husky's by placing another spark plug outlet in it.  Your thoughts?
« Reply #5 on: January 25, 2011, 09:43:39 pm »
Too much compression?
KTM come with about 5 different thicknesses for base gaskets. When you pull her down you need to check the clearance from the top of the barrel to the top of the piston at TDC I think it's about 1.2 mm but check. My new 250 I bought was the other way had a too thick base gasket.
Darryl Lewis has a new 390 pipe that makes them nicer to ride plus it looks heaps better than stock.
Offline Tossa
« Reply #6 on: January 25, 2011, 11:01:35 pm »
already got the pipe, will check the base gasket.  Have alook at the thread you can see it on the bike
Offline IT490K1983
« Reply #7 on: January 25, 2011, 11:54:49 pm »
Thank you, that will do nicely.  ;)
