Author Topic: Power steering fluid  (Read 4332 times)
TooFastTim
« on: January 04, 2011, 02:21:48 pm »
What fluid do you put in the power steering? Never had to top it up yet.
Offline sudman
Re: Power steering fluid
« Reply #1 on: January 04, 2011, 02:29:03 pm »
ATF same as some use in there forks.
« Reply #2 on: January 04, 2011, 02:30:19 pm »
What type of car and engine? as there are quite a few different types now.
Offline BAHNZY
« Reply #3 on: January 04, 2011, 02:33:21 pm »
On the cap of the reservoir the oil spec will be noted, but most important, if you have to top it up by 50ml (as a guess) then you have a 50ml leak somewhere in the system.
Rod (BAHNZY) Bahn
TooFastTim
« Reply #4 on: January 04, 2011, 02:46:38 pm »
Nissan x-trail. I looked on the cap but it just says: "Use power steering fluid". It's just on the minimum and I suspect it hasn't been youched in 130,000 k's.
Offline Canam370
« Reply #5 on: January 04, 2011, 02:55:07 pm »
Is being youched a good or bad thing? :)
TooFastTim
« Reply #6 on: January 04, 2011, 02:57:39 pm »
Youched is similar to being touched but it hurts  8)
Offline crash n bern
« Reply #7 on: January 04, 2011, 03:34:59 pm »
Someone told me the other day that you can use 50 weight engine oil and it works better and swells the seals.  Dunno? he owned a wrecking yard so he would have some car knowledge.
TooFastTim
« Reply #8 on: January 04, 2011, 03:46:40 pm »
monaro308
« Reply #9 on: January 04, 2011, 04:14:14 pm »
Being a "wrecker" i think its  car no knowledge and can just about f@#k every car in the yard under 16 y/old  :P
« Last Edit: January 04, 2011, 04:15:48 pm by monaro308 »
« Reply #10 on: January 04, 2011, 04:38:20 pm »
If it's just on the minimun leave it alone.
Offline BAHNZY
« Reply #11 on: January 04, 2011, 04:44:10 pm »
Im taking a guess that its a T30 X-Trail as the T31 has an electic power steering system fitted.
We recommend that you use DEXRON-III ATF in that system.
Rod (BAHNZY) Bahn
Offline pancho
« Reply #12 on: January 04, 2011, 04:52:45 pm »
Like bahnzy said.  Plus some Honda ,Mitsubishi models and various others use special  fluid not ATF
 also that wrecker would sell a few power steering units I reckon.
  cheers pancho.
TooFastTim
« Reply #13 on: January 04, 2011, 05:17:41 pm »
Thanks guys. Dexron III ATF it is.
« Reply #14 on: January 04, 2011, 06:10:30 pm »
Yeah, I was a bit dubious, he was reffering to older cars.  But I figured I'd just keep pouring the proper stuff in anyway.
