Author Topic: RM 400T clutch parts  (Read 1770 times)
Offline maxi81
« on: January 04, 2011, 02:04:06 pm »
After a clutch hub for RM 400T
monaro308
Re: RM 400T clutch parts
« Reply #1 on: January 04, 2011, 04:20:04 pm »
That might be a toughy as suzi parts show only the 400N and T match up as a source for parts.
Doc would know ALOT better than me  ;D
211kawasaki
« Reply #2 on: January 06, 2011, 03:29:17 pm »
PM me a picture I have a box of RM clutch bits
Dave
DR
« Reply #3 on: January 06, 2011, 05:16:06 pm »
I can't say I know :-\ never had a '79/'80 model to compare with the early stuff . Pretty sure I'd have a spare 370/400c hub if it is the same...
« Reply #4 on: January 06, 2011, 05:51:11 pm »
Doc,   Rm 400 T wear badly on the fingers much the same as Pe 400 do.
Dave , hold onto your gearbox set as you may need it one day  ;)
Offline maxi81
« Reply #5 on: January 06, 2011, 10:17:43 pm »
Hey Doc. The part number for the hub is the same as the 400T according to alpha sports. I imagine that this would make it the same part?
monaro308
« Reply #6 on: January 07, 2011, 01:39:27 am »
RM370B Hub                        21411-40100
RM370B Basket/gear asm       21200-40101
RM400C  Hub                       21411-40100
RM400C  Basket/gear asm      21200-40101
RM400N  Hub                       21411-40400
RM400N Basket/gear asm       21200-40400
RM400T Hub                        21411-40400
RM400T Basket/gear asm       21200-40400
PE400T Hub                         21411-40901
PE400T Basket/gear asm        21200-40901
I can only see RM400N and T hub and basket thats the same....PE no good either  - primary kick start
