Author Topic: MK 6 Bultaco 125  (Read 23894 times)
Offline Stan S
  • Ballarat Victoria
Re: MK 6 Bultaco 125
« Reply #30 on: January 06, 2011, 05:15:18 pm »
See what I can do Stanley. Was that Kawasaki contact helpful for you? Jerry
Yes Jerry, thanks very much.
Stan.
« Reply #31 on: January 16, 2011, 07:47:58 pm »
Have a feeling my MK6 has a MK7 frame. MK7 is chome moly how can I tell? Any help appreciated. Cheers Jerry
« Reply #32 on: January 16, 2011, 10:10:15 pm »
Jerry, Jerry, Jerry
The best way is to drive over it with a truck
If it flattens completly then it is just mild steel
If it only half flattens then it is Cro-Mo
Offline Stan S
  • Ballarat Victoria
« Reply #33 on: January 16, 2011, 10:18:35 pm »
What is the frame number Jerry?
Regards Stan.
« Reply #34 on: January 17, 2011, 10:37:23 am »
Hi Stan VB10001410 (matching engine # by the way) I have looked up the # and it tells me it's a MK6 but it has a tab welded on the rear stay (exhaust side) that I've only seen on a MK7 as well as a little loop thing welded near the swing arm pivot on the other side. It looks like an anchor point for a ?return spring for the rear brake. Also the the swingarm lower shock mounts have been beefed up considerably and maybe moved forward ?approx 1cm. The mods look professionally done.Maybe by the Floods ???? Cheers Jerry PS As for you Geoff get yourself ready for another visit to discuss a pipe for this project. Im thinking Titanium if your up for it!
