Author Topic: Another stray dog finds a new home  (Read 4016 times)
« on: December 30, 2010, 12:37:20 pm »
Bit rough around the edges but she has plenty of potential 8)  It's rm 250 1977  which will end up being my pre 78 ride.
As you can see it's missing a air box so if anyone can put me onto one it would be much appreciated . Vintage Suzuki have reproductions but have been advise I  need mounting hardware along with a cage .
Not too sure if it has correct tank as filler is centre and i thought they where a tad off centre ( to RHS )
« Last Edit: December 30, 2010, 12:41:58 pm by oldfart »
Re: Another stray dog finds a new home
« Reply #1 on: December 30, 2010, 01:48:39 pm »
A tank Stu.
Offline suzuki27
« Reply #2 on: December 30, 2010, 01:55:21 pm »
The A had the centre hole in tank from memory ,but the rest looks like a  B .
The engine on the B is much better I reckon.
Offline suzuki27
« Reply #3 on: December 30, 2010, 01:57:43 pm »
The filter cage and mounting plate etc is still available NOS and I will have a look for an airbox.
« Reply #4 on: December 30, 2010, 02:50:50 pm »
He knows that agent 27....it's just he's a tightarse plumber......he wants someone to cough it all up for $15..... ;D
« Reply #5 on: December 30, 2010, 03:00:54 pm »
Thanks 27 ...I know I can buy the filter assembly NOS but it's the air box bits that elude me .
Crocka shit, I'm penny less after you fleeced me the other day  ;)
« Reply #6 on: December 30, 2010, 03:18:52 pm »
As he drove away in his brand new ute!!
SAABCOMBI
« Reply #7 on: December 30, 2010, 04:29:01 pm »
was the photo taken from the roof top of your house.
Offline suzuki27
« Reply #8 on: December 30, 2010, 06:06:51 pm »
Thanks for the tip DC- I will adjust the price accordingly!!!!
« Reply #9 on: December 30, 2010, 06:54:42 pm »
David , almost  ;D  taken from rear deck. And just for you a ground level shot  ;D
Pulled the barrel of and it's had a fresh rebore .05 of which still has hone marks.
It's pulled a head stud at  and blown a head gasket  which probably saved it's life
 it appears a low hour motor with unmolested case screws  :)
« Last Edit: December 30, 2010, 06:56:24 pm by oldfart »
« Reply #10 on: December 31, 2010, 06:51:35 pm »
split the cases today and discovered a chipped teeth and badly worn dogs  .. all is not lost Oldie  should have something lying around that will fit.
Problem being is I have too much.  ::)
Ah here we go a Rm 250 T gear set drops straight in and using the B  shift forks & drum  it works a treat  .... Primary drive  has same amount of teeth .
« Last Edit: December 31, 2010, 06:53:40 pm by oldfart »
« Reply #11 on: January 02, 2011, 06:02:47 pm »
Stripped the  frame down and found a bit of rust under foot peg RHs  , rest of frame was pretty solid
Drilled a series of 1/8 holes until I found solid metal .
« Last Edit: January 02, 2011, 06:05:04 pm by oldfart »
Offline PERM250
« Reply #12 on: January 02, 2011, 06:38:58 pm »
GREAT WORK STU SHOULD TURN OUT GREAT
SAABCOMBI
« Reply #13 on: January 02, 2011, 09:08:53 pm »
thanks old fart, now l can see it, what a good find.
