Author Topic: RM crankshaft  (Read 6374 times)
Offline maxi81
RM crankshaft
« on: December 22, 2010, 07:11:31 pm »
Is this fixable??
Re: RM crankshaft
« Reply #1 on: December 22, 2010, 07:14:16 pm »
What model RM?...may be cheaper to get a secondhand one or a new crank half.
Offline maxi81
Re: RM crankshaft
« Reply #2 on: December 22, 2010, 07:21:33 pm »
RM 400T. I've found it a bit hard to source a second one
DR
Re: RM crankshaft
« Reply #3 on: December 22, 2010, 07:23:11 pm »
If it were mine it'd be tossed in the scrap bin ;)
No matter what model RM I'd reckon another crank would be the way to go. If you can't get one locally then the US maybe the go..will see what I can hunt up ;)
Offline maxi81
Re: RM crankshaft
« Reply #4 on: December 22, 2010, 07:25:38 pm »
Thanks for that Doc
Re: RM crankshaft
« Reply #6 on: December 22, 2010, 07:36:57 pm »
What happened to that  ???
Offline maxi81
Re: RM crankshaft
« Reply #7 on: December 22, 2010, 07:37:50 pm »
Do you think they look okay? I''m no expert
Offline maxi81
Re: RM crankshaft
« Reply #8 on: December 22, 2010, 07:40:03 pm »
Crank gear was welded onto crank for some reason. It was my dad's bike.
Re: RM crankshaft
« Reply #9 on: December 22, 2010, 07:55:11 pm »
Is this fixable??
YES but only if you cant get another one. Try to get another second hand one first. If you cant then any decent machinst/crank repairer can fix that.
Re: RM crankshaft
« Reply #10 on: December 22, 2010, 08:37:18 pm »
Typical .... nut has come loose on primary drive , gear was able to chatter away on key way,   and this is the end result.
Offline holeshot buddy
  • sunshine coast qld
Re: RM crankshaft
« Reply #11 on: December 22, 2010, 08:48:05 pm »
common problem on big bore suzys
follow me to first turn
Re: RM crankshaft
« Reply #12 on: December 22, 2010, 09:09:43 pm »
It is quite 'easily' fixed. Those Swedish $hitters Huskervarna's have press in ignition tapers probably for similar reasons if that part ever gets damaged.
To fix it a new primary shaft end would be machined and heat treated and final ground to size. then the shaft on the crank web would be cut off and then a hole EDM wire cut or CNC machined out. The 2 components then pressed together.
Do not let anyone weld another repair section onto the existing crank as that will end in tears.
Re: RM crankshaft
« Reply #13 on: December 22, 2010, 10:57:29 pm »
Agree
DR
Re: RM crankshaft
« Reply #14 on: December 22, 2010, 11:58:24 pm »
Sounds like a lot of trouble to repair when another crank is available..it's not like it's an RN400 crank :-\
This crank below 'appears' to be from a 1979 RM400N going by the numbers supplied. If correct it will bolt straight into the '80 400T. The seller say's no up and down play but there is lateral movement. This lateral movement he mentions is probably quite normal and it may well be useable as is but rebuilding it would be the go especially if you can get it sent over for a reasonable price in the first place. I hate to recommend anything as it always seems to turn around and bite me on the arse but eh..that's the one I'd be looking at. Email the seller and ask the questions ;)
http://cgi.ebay.com/ebaymotors/SUZUKI-RM400-RM-400-ENGINE-CRANK-SHAFT-CON-ROD-_W0QQcmdZViewItemQQhashZitem3eedd3425fQQitemZ270278017631QQptZMotorcyclesQ5fPartsQ5fAccessories
there is another further down the page that lists a crank for $100 but it lists it for both the RM400 and RM465 which are not interchangeable so I've no idea what he's on about to start with ??? might be an okay thing too but he needs to dicide if it is RM400 or RM465 ;)
