Author Topic: B44 electrics  (Read 5461 times)
Offline bazza
B44 electrics
« on: December 20, 2010, 05:46:48 pm »
Looking at  pomy Electix rotor kit/ CDI any one used one of these?
Embrace patina
Re: B44 electrics
« Reply #1 on: December 20, 2010, 05:58:06 pm »
Electrex? from what I hear they a pretty good, should be better than the Lucas stuff. There is an Australian importer for them in QLD. Although with a new set of points and properly set up, points can still be ok. A lot of the people who winge about the BSA energy transfer system dont know how to set them up right.
Offline bazza
Re: B44 electrics
« Reply #2 on: December 20, 2010, 06:09:58 pm »
my points are working well-Local fitted one and his now starts easy as.
Embrace patina
Offline Marc.com
Re: B44 electrics
« Reply #3 on: December 22, 2010, 07:50:20 am »
I am running Pazon ignition, they are made in NZ and reasonable price. comes with complete instructions and you can run pretty minimal wiring.
Offline big mac
Re: B44 electrics
« Reply #4 on: December 22, 2010, 12:56:46 pm »
I used electix kits in both my B44 & B50 both start well & pull great through the rev range easy to install the only thing I did was to make different diameter spacers for mounting the stator. What I did learn was that you should wrap a alloy can around the rotor to get the gap even when you tighten the stator plate.
Offline bazza
Re: B44 electrics
« Reply #5 on: December 22, 2010, 06:30:03 pm »
Thanks guys, Mark saw those were made down here,have you used the motor regularly for reliabilty,easy start etc? merry xmas up there
Embrace patina
Offline bazza
Re: B44 electrics
« Reply #6 on: December 24, 2010, 08:26:16 am »
Mark do you run a battery with the Pazon system?
Embrace patina
Offline Marc.com
Re: B44 electrics
« Reply #7 on: December 25, 2010, 02:08:20 am »
Yeah you have to run a battery, Cheney is set up for it so no biggie for me.
