Author Topic: Carby problem, I think...  (Read 2403 times)
Stewy138
« on: December 19, 2010, 10:56:20 pm »
I have a PE175C which I recently changed the carby from 32mm to 34mm.  The other change at the same time was fitting an inner rotor ignition with an RM125A CDI.
Anyway, when I ride the old gal hard (no I'm not talking about my personal life, I'm referring to the PE now) then back off the throttle, eg on a downhill section, the engine starts to die (like its running out of fuel).  If I give it a good handful of throttle it recovers ok but will start to die away again if I start to back off.  Only does this when the engine is hot and doesnt seem to happen when I'm not riding as hard, and the engine presumably is a bit cooler.
Its not over-revving when it dies, so I dont think its running lean.  The plug is sooty and slightly oily after a ride.
Any thoughts  ????
Thanks,
Stewy.
Offline vandy010
  • #789 MX125a BMCC Brisbane
Re: Carby problem, I think...
« Reply #1 on: December 19, 2010, 11:13:03 pm »
what size pilot jet Stewy?
« Last Edit: December 20, 2010, 08:25:32 am by vandy010 »
"flat bickie"
Stewy138
« Reply #2 on: December 22, 2010, 02:40:33 pm »
Hey Vandy,
Yes i was thinking along those lines...the new card was apparently from an RM125M and the jets were all way different to the ones in the 32mm PE carb.  So I changed out all the jets from the 32 PE carb into the 34mm body.  Then went to a significantly bigger main jet (260, original was 190).  Logic tells me that the pilot would need to be larger too.
Will extract it and have a look...
« Reply #3 on: December 22, 2010, 05:57:41 pm »
Do a proper plug chop and post a pic of the plug.Alternatively kill the engine while the problem exists.
Offline oldyzman
  • 250 two stroke!
« Reply #4 on: December 22, 2010, 06:23:11 pm »
Is there any possibility the choke is faulty and not turning off properly..
Brett
« Reply #5 on: December 22, 2010, 06:32:30 pm »
check to see is float level is correct height.
« Reply #6 on: December 22, 2010, 07:09:51 pm »
Make sure your misses hasnt burnt the muffins ;D
