Clubroom
Bike Talk
spring hose covering
Topic: spring hose covering (Read 5664 times)
LWC82PE
Superstar
January 21, 2008, 11:11:07 pm »
so ok where can you get this coil spring hose covering? i dont need it for shock hose just at the moment but i need it for different hose that is about 19mm OD. i went to about 6 places this morning but no one has it. eveyone said try car radiator places but they dont have it all their stuff is much bigger than 19mm. is this another item i have to source from USA? i have found it on a USA site but they want $50US for a wire tansfer fee
http://www.hosexpress.com/hydraulic/accessories/900564.htm
Last Edit: January 21, 2008, 11:13:28 pm by LWC3077
YSS
Re: spring hose covering
January 21, 2008, 11:18:22 pm »
Use Adelaide Industrial springs , they can make any spring , but they only have grade 2 wire , but for this application that is more than plenty.
LWC82PE
Superstar
January 21, 2008, 11:20:42 pm »
right i will try them then
Rosco400
January 22, 2008, 09:28:12 am »
Bunnings in the plumbing section has an assortment of springs, used for bending and protecting PVC pipe both internally and externally, come in different sizes and grades, worth having a look anyway, can always bring something elses home
YSS
Reply #4 on:
January 22, 2008, 11:04:29 am »
Be aware that the springs go on the hose before the crimping process.
LWC82PE
Superstar
Reply #5 on:
January 22, 2008, 12:58:00 pm »
i do need new shock hose like that but not just right now. i want the spring for much larger hose (19mm OD) that is not having crimped ends. just covered hose clamps (hose finishers)
Reply #6 on:
January 22, 2008, 04:48:38 pm »
Enzed hose doctor - Pirtek - any hydraulic hose supplier should be able to help out
Freakshow
Superstar
Adelaide, SA - looking for a "YZA" tank
Reply #7 on:
January 23, 2008, 09:45:32 pm »
couple of coat hangers
Last Edit: January 23, 2008, 09:48:16 pm by Freakshow
74 Yamaha flattracker's
70 Jawa 2 valve speedway's
For sale - PRE 75 Yamaha MX stuff, frame, motors and parts also some YAM DT1,2,A and Suzi TS bikes and stuff
LWC82PE
Superstar
Reply #8 on:
January 23, 2008, 09:50:26 pm »
tried Enzed and was surprised when they didnt have it. i think im just gonna have to get my USA mate to do a favour and get some for me from over there. i think its a bit hard to get as its all gone to that stainless steel braided stuff and they dont use the spring covering much anymore.
Last Edit: January 23, 2008, 09:55:22 pm by LWC3077
Reply #9 on:
January 25, 2008, 07:22:19 pm »
What size ID and length are you after .
LWC82PE
Superstar
Reply #10 on:
January 25, 2008, 10:25:12 pm »
19mm ID about 300 or longer. i would probably get decent amount of it since its not the easiest thing to get
Clubroom
Bike Talk
