Author Topic: dt square swingarm  (Read 3189 times)
dt square swingarm
« on: December 07, 2010, 02:35:30 am »
Hi guys here is a rule book ? the dt1 pre 70 needs a square swing arm , why can't I use a rt1 round swing arm its pre 70.thanks in advance Iainyz
DR
Re: dt square swingarm
« Reply #1 on: December 07, 2010, 06:09:55 am »
If it is pre'70 it is pre'70, that cannot be disputed ;) I think the square swingarm bit was to distinguish the early legal dt1 from the later models.
« Reply #2 on: December 07, 2010, 07:44:44 am »
You can use the round swing arm - I can't recall the exact wording: The bit about needing a square swing arm is still there, but there's also a bit about using any DT1/RT1 with a piston port barrel. This lets you use round swing arms, late frames, etc.
« Reply #3 on: December 07, 2010, 09:29:52 am »
Ian....you've found one of those quirky anomolies in the rulebook. Rule 18.7.4.1 states "Yamaha: AT1*,DT1,CT1* rectangular swingarm, DT1, RT1 pre reed block"The rectangular section swingarm requirement was in the rulebook long before the RT1 was declared eligible for the class as a 'flow on' and it hasn't been removed. The round section swingarm is legal. The eligibility criteria could do with a hefty tuneup but when you condider that it was developed by Peter Drakeford and his team nearly 20 years ago, it's served us well. Common sense usually prevails where anomolies occur
* A good example of the 'mistakes' in the eligibility criteria is that although the book calls for rectangular swingarms for Yamaha AT1 and CT1 models, they were never equipped with them and the DT1 arm doesn't fit.
« Reply #4 on: December 07, 2010, 12:09:54 pm »
Thank you all , as I have two dt1 non reed that only needed swing arms all is well as I've got two round ones thanks again
« Reply #5 on: December 07, 2010, 03:02:56 pm »
Gort a square one here, swap you for a round one if your worried ?
« Reply #6 on: December 07, 2010, 03:19:10 pm »
Not worried now Freaky thanks for the offer though just making shaw Im legal .
« Reply #7 on: December 07, 2010, 04:34:26 pm »
For CB 2011 youl be fine :O)
