Author Topic: DT250A  (Read 3240 times)
Offline oldDT
DT250A
« on: January 21, 2008, 04:25:32 am »
I started on this bike 18 months ago, but now have 2 grandkids keeping me busy with other bike projects so this one has to go. The frame and swing arm have been sand blasted, inspected and painted. Had new swing arm bushes made up. Has 76 forks fitted at present, but the 74 ones come with the bike. Both rims are there and straight. Tank has a couple of small dings and the inside is rusted. No fuel tap. No side covers or front guard. The rear steel guard is there, but needs straightening. The air box and exhaust are there. The motor is there complete, turns over freely and selects all gears. Has some (read little) compression. Carbie is there but looks like a bitsa. The rubber reed block is perished.
My dog chewed the wiring from the case. I think I can locate the coil, but that's it for electrics. The kick start is NOT welded on, but the gear lever is. Has bars and a couple of lever perches as well. Probably a few other bits floating about as well (oil tank etc)
Bike is located in Brisbane (north) for pickup. Would love to finish it, but grand kids take precedent.
Re: DT250A
« Reply #1 on: January 21, 2008, 01:18:55 pm »
Posting a picture might help out here Old DT, if you can post a picture and the price you might better your chances of moving it on.
If you dont know how to post a pic sing out and somone can help you get it up .
Good luck.
Offline oldDT
Re: DT250A
« Reply #2 on: January 22, 2008, 03:16:44 am »
Thanks for that Freaky ::) Don't have a pic, and the price is, or isn't. Come and take it away. I'd rather see it go to someone who can either finish it or at least use the parts than see it sitting here collecting dust and cobwebs.
Kel
Re: DT250A
« Reply #3 on: January 22, 2008, 09:10:50 am »
Shit, can't go wrong at that price!
I'll see what I can organise transport wise....
Re: DT250A
« Reply #4 on: January 22, 2008, 04:55:17 pm »
Nathan ... if your keen maybe i might be able to help with pick up and storage as I will be going up that way soon.
Re: DT250A
« Reply #5 on: January 23, 2008, 09:15:07 am »
Cheers Oldfart. I've already got Doc on the case, but it it's less hassle for you, then great. :)
I assume you and Doc talk at least semi-regularly? I'll send you both a PM and you can sort it out - and I'll be in debt to both of you, rather than just one...  :D
You coming to CD5?
