Author Topic: Parts for a Suzuki RM125S  (Read 2662 times)
Mark Austin
« on: December 04, 2010, 06:47:48 pm »
Hi ,
I have a "el cheapo" project I'm working on, and I need a few parts to get it going. Here's what I need:
Fuel tank - could be off a TM125, RM125S, RM100 - anything later and it won't look right
Rear wheel axle and spacer - could be from any TS, TC, RM100,125 or GT185
Original rear shockies - I know they should probably be replaced, but they're a good place to start
Kickstart lever
Any help will be greatly appreciated.
Mark
« Last Edit: December 04, 2010, 06:50:36 pm by auscobul »
Offline Graeme M
  • Administrator
  • Canberra, Australia
Re: Parts for a Suzuki RM125S
« Reply #1 on: December 04, 2010, 06:59:35 pm »
Mark, I have the shocks off my RM125M which may be originals. They do need rebuilding though.
Offline Canam370
« Reply #2 on: December 04, 2010, 07:08:00 pm »
Kickstarter is still available new and not that expensive either.
Mark Austin
« Reply #3 on: December 04, 2010, 07:25:15 pm »
Hi Graeme,
That sounds good, I can rebuild them I reckon. What shocks are you using now?
I'll also check out the "factory" kickstarter - thanks.
Mark
Offline Graeme M
  • Administrator
« Reply #4 on: December 05, 2010, 08:15:07 am »
Mark I am currently running YSS which work well. I'll try to remember to dig out the originals today and have a look at them.
« Reply #5 on: December 05, 2010, 12:14:47 pm »
I think i have a exht pipe i bought for a 250TM but when it turned up its not a250 looks 125TM and also a TM tank.   WHat kinda coin is elcheapo as i need to cover my original investment.   ( i forked up with the exh and too exp to send back)
Offline Graeme M
  • Administrator
« Reply #6 on: December 06, 2010, 08:28:12 pm »
Mark, the shocks look fine but definitely need new seals. Someone has tapped air valves into the bodies so I guess they can be recharged more easily. If you are interested, just PM me your address. Yours for the price of postage.
Mark Austin
« Reply #7 on: December 06, 2010, 10:49:13 pm »
Hi Freakie,
Let me know what you want for them
Mark
Offline Suzukal
« Reply #8 on: December 06, 2010, 10:53:53 pm »
Hi Graeme .. those shocks from your bike were the original ones that came with the bike when I had it, they were modified by Stacker motorcycles to be rebuildable.
Offline Graeme M
  • Administrator
« Reply #9 on: December 10, 2010, 02:38:04 pm »
That's right, I remember you saying that.
They look pretty tidy, so with that mod they should be easy enough and cheap to fix (just need seals I think). Posted them off today Mark. Do you still need an axle? I may have one lying around at home as well.
Mark Austin
« Reply #10 on: December 11, 2010, 09:31:34 pm »
Hi Graeme,
Thanks for posting them, I do still need a rear axle if you have one.
I'm away until next Monday, so I'll sort it all out when I get back.
Thanks for your help.
Mark
